I am trying to control 5 servo motors to specific angles given by a PC via Xbee . A code (encoded servo number and angle ) will be sent from the PC via an Xbee transmitter and will be received using an Xbee receiver. The arduino should convert the received code to angles & servoes and perform the operation. I want the assistance with the code. Any help is welcomed...
Hey,
Um not so sure about the code but this shield would be perfect for your project. It supports up to 8 servo ports, which is more than enough for you, and has a space to directly connect an xbee receiver to the shield.
hope this helps a little.
For only five servos, why bother with a shield?
I have got the hardware, I am using the PWM pins of the ARDUINO itself and no other external boards. But i need help in coding the program as I had explained above. I want to serially control multiple servoes, thats all...
Don't use PWM to drive R/C servos.
Use the servo library.
Well, show us what you've got so far, and then we should be able to help you.
Yes , I am using servo library and the PWM pins. Please someone help me on how should I encode the servonumber and angle to send from PC and the code to decode it in the arduino , and rotate the corresponding servos to received angles ???
AWOL:
// Import the Arduino Servo library
#include <Servo.h>
// Create a Servo object array for all the 5 servos
Servo servo[6];
// Common servo setup values
int minPulse = 600; // minimum servo position, us (microseconds)
int maxPulse = 2400; // maximum servo position, us
int userInput[4]; // User input for servo and position , raw input from serial buffer, 3 bytes
int startbyte=0,start=0,hault=0,endbyte=0; // start byte (begin reading input),end byte (end reading input),start( started getting data ), hault ( data reception ended )
int num=0,pos=0,i; // num = servo number, pos = angle to take , i for itration
// Attach each of the 6 Servo object to a digital PWM pin
servo[0].attach(3, minPulse, maxPulse);
servo[1].attach(5, minPulse, maxPulse);
servo[2].attach(6, minPulse, maxPulse);
servo[3].attach(9, minPulse, maxPulse);
servo[4].attach(10, minPulse, maxPulse);
servo[5].attach(11, minPulse, maxPulse);
// Open the serial connection, 9600 baud
// Wait for serial input (min 6 bytes in buffer)
if (Serial.available() >= 6)
startbyte = Serial.read(); // receive the first byte
if (startbyte == '<') // check if it is '<' or not
start=1; // if the start bit is correct the code reception starts
for (i=0;i<4;i++)
userInput[i] = Serial.read()-'0'; // reads and stores the 4 values received as numbers in an array
endbyte= Serial.read(); // receive the 6th bit
if(endbyte=='>') // if it is the ending byte then
hault=1; // data reception ended
if ( start==1 && hault==1) // if data was successfully received
num = userInput[0]; // identifying the servo from the code
pos =(userInput[1]*100)+(userInput[2]*10)+userInput[3]; // calculating angle from the next 3 bits of the received code ( 3 bytes to one value conversion )
Serial.print("Servo No: "); // acknowledging the transmitter with the decoded data , angle and servo
Serial.print(num+1);
Serial.print("Angle : ");
Serial.print(pos);
servo[num].write(pos); // rotate the corresponding dervo to the received angle
delay(100); // wait till servo reaches that position
hault=0,start=0;
the data sent from the pc will be of the format
<(servonumber)(servo angle in 3 digits)>
The sketch looks to be OK, what's the problem?
Below is some code I use to test servos I have that might be of interest.
// zoomkat 11-22-10 serial servo (2) test
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
// two servo setup with two servo commands
// send eight character string like 15001500 or 14501550
#include <Servo.h>
String readString, servo1, servo2;
Servo myservo1;Â // create servo object to control a servo
Servo myservo2;
 myservo1.attach(6); //the pin for the servo control
 myservo2.attach(7);
 Serial.println("servo-test-21"); // so I can keep track of what is loaded
 while (Serial.available()) {
  delay(1);Â
  if (Serial.available() >0) {
   char c = Serial.read(); //gets one byte from serial buffer
   readString += c; //makes the string readString
 if (readString.length() >0) {
   Serial.println(readString); //see what was received
  Â
   // expect a string like 07002100 containing the two servo positions  Â
   servo1 = readString.substring(0, 4); //get the first four characters
   servo2 = readString.substring(4, 8); //get the next four characters
  Â
   Serial.println(servo1); //print to serial monitor to see results
   Serial.println(servo2);
  Â
   int n1; //declare as numberÂ
   int n2;
  Â
   char carray1[6]; //magic needed to convert string to a number
   servo1.toCharArray(carray1, sizeof(carray1));
   n1 = atoi(carray1);
  Â
   char carray2[6];
   servo2.toCharArray(carray2, sizeof(carray2));
   n2 = atoi(carray2);
  Â
   myservo1.writeMicroseconds(n1); //set servo position
   myservo2.writeMicroseconds(n2);
  readString="";
