Servo controlled dimmer
Just finished cutting and assembling this today. The junction box contains a dimmer, an outlet, and a servo. Top socket supplies power to the arduino while bottom socket provides power to a lamp of some sort (in this case a work lamp, mostly for demonstration purposes.)
I don't want to give away the ending, but once I finish the assembly of the remaining 2 parts, the entire arduino rig will be contained inside the junction box, making for a really nice, clean, finished product.
(Full blog post here)
Simple idea but very professionally executed. Do you have any notes on the actual build? You've got a nice little box there :slight_smile:
After a few weeks of use, I found there to be some inherent flaws in the pulley design, so I modified it to use a pair of gears instead.
TeamMCS: Simple idea but very professionally executed. Do you have any notes on the actual build? You've got a nice little box there
First of all: thank you.
Second: I do indeed have build notes. They can be found on thingiverse.
The original pulley version: Arduino controlled Dimmer Switch by asp55 - Thingiverse
The updated geared version:http://www.thingiverse.com/thing:698
