Robin,
Using another pair of pins is the obvious "workaround", which was next on the list assuming I can't figure out how to detach the servo library.
I'm not really sure how posting the entire program would enhance my post or contribute more than I've already said. However here is the code using digital writes, in place of analog writes.
#include <IRremote.h>
#include <Servo.h> //servo library
Servo myservo; // create servo object to control servo
int receiverpin = 12;
int in1=6;
int in2=7;
int in3=8;
int in4=9;
int ENA=5;
int ENB=10;
int ABS=100; //PULSE WIDTH SPEED CONTROL
unsigned long RED;
#define A 16736925
#define B 16754775
#define X 16712445
#define C 16720605
#define D 16761405
IRrecv irrecv(receiverpin);
decode_results results;
void _mForward()
digitalWrite(ENA,ABS);
digitalWrite(ENB,ABS);
digitalWrite(in1,LOW);
digitalWrite(in2,HIGH);
digitalWrite(in3,LOW);
digitalWrite(in4,HIGH);
Serial.println("go forward!");
void _mBack()
digitalWrite(in1,HIGH);
digitalWrite(in2,LOW);
digitalWrite(in3,HIGH);
digitalWrite(in4,LOW);
Serial.println("go back!");
void _mleft()
digitalWrite(ENA,HIGH);
digitalWrite(ENB,HIGH);
Serial.println("go left!");
void _mright()
Serial.println("go right!");
void _mStop()
digitalWrite(ENA,LOW);
digitalWrite(ENB,LOW);
Serial.println("STOP!");
myservo.attach(3); // attach servo on pin 3 to servo object
myservo.write(85); //set servo to center
delay(200);
myservo.detach(); // detach servo
delay(200);
pinMode(in1,OUTPUT);
pinMode(in2,OUTPUT);
pinMode(in3,OUTPUT);
pinMode(in4,OUTPUT);
pinMode(ENA,OUTPUT);
pinMode(ENB,OUTPUT);
pinMode(receiverpin,INPUT);
_mStop();
irrecv.enableIRIn();
if (irrecv.decode(&results))
RED=results.value;
Serial.println(RED);
irrecv.resume();
delay(150);
if(RED==A)
_mForward();
else if(RED==B)
_mBack();
else if(RED==C)
_mleft();
else if(RED==D)
_mright();
else if(RED==X)
_mStop();
