servo.detach wanting to know how it is used in this piece of code
I have been studying arduino coding for a few days now and found a website that talked about millis and servos. I'm basically delving into lots of different codes, pulling them apart and seeing how they work etc.
The website I found this code on is All together now! | Multi-tasking the Arduino - Part 1 | Adafruit Learning System
Wonderful topic and the code works very nicely and I learned heaps from it.
I used one part of the code to move a servo and took away all the rest of the code and found one part very interesting.
The code that I am looking at is>>>
#include <Servo.h>
class Sweeper
Servo servo; // the servo
int pos; // current servo position
int increment; // increment to move for each interval
int updateInterval; // interval between updates
unsigned long lastUpdate; // last update of position
public:
Sweeper(int interval)
updateInterval = interval;
increment = 1;
void Attach(int pin)
servo.attach(pin);
void Detach()
servo.detach();
void Update()
if((millis() - lastUpdate) > updateInterval) // time to update
lastUpdate = millis();
pos += increment;
servo.write(pos);
Serial.println(pos);
if ((pos >= 80) || (pos <= 0)) // end of sweep
// reverse direction
increment = -increment;
Sweeper sweeper1(15);
Sweeper sweeper2(15);
sweeper1.Attach(9);
sweeper2.Attach(5);
sweeper1.Update();
sweeper2.Update();
The part of the code I wanted to find out about is...
void Detach()
servo.attach(pin);
The code still moves the servo when this bit of code is removed, so I just wanted to find out why it is there.
I'm thinking it may be part of a loop that has to detach then re-attach in order for the code to work.
Cheers,
Chris.
The Detach function is not being called in the improperly posted code.
groundFungus:
groundFungus:
I apologise to the board for the improperly posted code, will make sure I do it correctly for future posts.
detach() is a just standard function of the Servo.h library. It's not used very often in normal servo coding.
Why whoever wrote the Sweeper class chose to include a public method to call it is anyone's guess. Perhaps just for completeness or they thought they might need it one day.
Steve
slipstick:
Steve
Cheers steve, thanks for the great explanation and it was very helpful for my learning.
Have a great new year.
Chris.
If servo is detached then reattached it will move to the default 90 degree position when attached.
outsider:
If you write() to the servo before attaching it then it will move to the commanded position when attached
Correct. Save the last commanded position, then write it back before reattaching:
servo.write(posX);
servo.detach();
servo.write(posX);
servo.attach(9); // or whatever pin
All true but none of that really explains why detach() would be needed in a Sweeper class.
Steve
outsider:
Does it? I thought it retained the last value written.
@AWOL:
Well you were correct again. (Did I detect a smirk?) :stuck_out_tongue:
