Servo dies...
I'm just starting out with the Arduino - and loving it too. I'm trying to control a servo. I've got it wired onto pin 9. I have a simple sketch (not using the servo library - thought I'd do it by hand to help learn...) which allows me to type <> or . to move the servo left, right or centre it. By and large it works, but if I enter a string like '<<<<.>>>>....>' sometimes the servo just dies - offers no resistance to manual rotation and doesn't obey any inputs. All debugging gives expected results.
Here's the sketch:
const int servoPin = 9;
const int fullLeft = 900;
const int centre = 1500;
const int fullRight = 2100;
const int turnRate = 100;
const int refreshPeriod = 20; //20ms
int lastRefresh = 0;
  Serial.println("Enter '<' to turn left, '>' to turn right or '.' to centre");
  pinMode(servoPin,OUTPUT);
  int ch;
  int pulseWidth = centre;
  for(;;){
    if (Serial.available()) {
      ch = Serial.read();
      if (ch=='<') {
        Serial.print("Sub ");
        Serial.print(turnRate,DEC);
        Serial.print(" from pulseWidth to give ");
        pulseWidth -= turnRate;
        Serial.println(pulseWidth,DEC);
      if (ch=='>') {
        Serial.print("Add ");
        pulseWidth += turnRate;
      if (ch=='.') {
      // Prevent over ranging
      pulseWidth = pulseWidth>fullRight?fullRight:pulseWidth;
      pulseWidth = pulseWidth<fullLeft?fullLeft:pulseWidth;
      Serial.print("New pulseWidth is ");
    if (millis()>lastRefresh+refreshPeriod) {
      digitalWrite(servoPin,HIGH);
      delayMicroseconds(pulseWidth);
      digitalWrite(servoPin,LOW);
      lastRefresh = millis();
Any ideas as to what's going wrong here would be appreciated.
Thanks, Mark
The answer is, of course, in the coding.
should of course be
unsigned long lastRefresh = 0;
to prevent lastRefresh from becoming negative every 30s or so... :-[
