Can anyone give me a hand changing the direction of of a micro servo using servo.h ?
Currently 3 of my servos operate in the same direction. I needed to flip one of them 180 degrees for space reasons.
I tried flipping the values in the sketch for servoC but that didn't work. Included is a rough drawing showing 3 of the 4 servos for reference.
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <Servo.h>
#define ssid "itwifi"
#define password "mis5436133"
ESP8266WebServer server(84);
Servo myservoA;
int posA = 0;
int stateA = 0;
int prevstateA = 0;
int dircA = 0;
int servoPinA = D4;
Servo myservoB;
int posB = 0;
int stateB = 0;
int prevstateB = 0;
int dircB = 0;
int servoPinB = D5;
Servo myservoC;
int posC = 0;
int stateC = 0;
int prevstateC = 0;
int dircC = 0;
int servoPinC = D6;
Servo myservoD;
int posD = 0;
int stateD = 0;
int prevstateD = 0;
int dircD = 0;
int servoPinD = D1;
String webPage = "";
delay(100);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
// Set a static IP (optional)
IPAddress ip(192, 168, 1, 72);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
WiFi.config(ip, gateway, subnet);
// End of set a static IP (optional)
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
webPage += "<BODY style='background-color:#0a88c2'>";
webPage += "<h1 style=\"color:#FBFCFC; text-align:center\">Treats for Lincoln</h1>";
webPage += "<hr/>";
webPage += "<h3 style=\"color:#FBFCFC; text-align:center\">Quiet Time (AM)<p><a href=\"deliverA\"><button>Deliver</button></a> <a href=\"resetA\"><button>Reset</button></a></p>";
webPage += "<h3 style=\"color:#FBFCFC; text-align:center\">Quiet Time (PM)<p><a href=\"deliverB\"><button>Deliver</button></a> <a href=\"resetB\"><button>Reset</button></a></p>";
webPage += "<h3 style=\"color:#FBFCFC; text-align:center\">Cup Of Treats<p><a href=\"deliverC\"><button>Deliver</button></a> <a href=\"resetC\"><button>Reset</button></a></p>";
webPage += "<h3 style=\"color:#FBFCFC; text-align:center\">Kong<p><a href=\"deliverD\"><button>Deliver</button></a> <a href=\"resetD\"><button>Reset</button></a></p>";
webPage += "<hr/>";
server.on("/", []() {
server.send(200, "text/html", webPage);
server.on("/deliverA", []() {
Serial.println("HTTP OPEN COMMAND RECEIVED");
dircA = 0; // direction for servo to run
stateA = 2; // sets current state
server.on("/resetA", []() {
Serial.println("HTTP CLOSE COMMAND RECEIVED");
dircA = 180; // direction for servo to run
stateA = 1; // sets current state
server.on("/deliverB", []() {
dircB = 0; // direction for servo to run
stateB = 2; // sets current state
server.on("/resetB", []() {
dircB = 180; // direction for servo to run
stateB = 1; // sets current state
server.on("/deliverC", []() {
dircC = 0; // direction for servo to run
stateC = 2; // sets current state
server.on("/resetC", []() {
dircC = 180; // direction for servo to run
stateC = 1; // sets current state
server.on("/deliverD", []() {
dircD = 0; // direction for servo to run
stateD = 2; // sets current state
server.on("/resetD", []() {
dircD = 180; // direction for servo to run
stateD = 1; // sets current state
server.begin();
Serial.println("Server started");
void servo_moveA() {
Serial.println("State Change. Rotating Servo");
if ( dircA == 180) {
myservoA.attach(servoPinA); // energize servo
delay(50);
for (posA = 0; posA <= 180; posA += 1) { // goes from 0 degrees to 90 degrees in steps of 1 degree CHANGE 90 TO MATCH ANGLE OF TILT DESIRED
myservoA.write(posA); // tell servo to go to position in variable 'pos'
delay(5); // waits 30ms between each degree to slow rotation speed
delay(50);
myservoA.detach(); // movement finished so detach servo to conserve power
else if (dircA == 0) {
delay(50);
for (posA = 180; posA >= 0; posA -= 1) { // goes from 90 degrees to 0 degrees in steps of 1 degree CHANGE 90 TO MIRROR ANGLE OF TILT DESIRED ABOVE
delay(50);
}// end if dirA
}// end servoA
void servo_moveB() {
if ( dircB == 180) {
myservoB.attach(servoPinB); // energize servo
delay(50);
for (posB = 0; posB <= 180; posB += 1) { // goes from 0 degrees to 90 degrees in steps of 1 degree CHANGE 90 TO MATCH ANGLE OF TILT DESIRED
myservoB.write(posB); // tell servo to go to position in variable 'pos'
delay(50);
myservoB.detach(); // movement finished so detach servo to conserve power
else if (dircB == 0) {
delay(50);
for (posB = 180; posB >= 0; posB -= 1) { // goes from 90 degrees to 0 degrees in steps of 1 degree CHANGE 90 TO MIRROR ANGLE OF TILT DESIRED ABOVE
delay(50);
}// end if dirB
}// end servoB
void servo_moveC() {
if ( dircC == 180) {
myservoC.attach(servoPinC);
delay(50);
for (posC = 0; posC <= 180; posC += 1) {
myservoC.write(posC);
delay(5);
delay(50);
myservoC.detach();
else if (dircC == 0) {
delay(50);
for (posC = 90; posC >= 0; posC -= 1) {
delay(5);
delay(50);
myservoC.detach();
}// end if dirC
}// end servoC
void servo_moveD() {
if ( dircD == 180) {
myservoD.attach(servoPinD);
delay(50);
for (posD = 0; posD <= 180; posD += 1) {
myservoD.write(posD);
delay(5);
delay(50);
myservoD.detach();
else if (dircD == 0) {
delay(50);
for (posD = 90; posD >= 0; posD -= 1) {
delay(5);
delay(50);
myservoD.detach();
}// end if dircD
}// end servoD
if (stateA != prevstateA) {
servo_moveA();
prevstateA = stateA;
if (stateB != prevstateB) {
servo_moveB();
prevstateB = stateB;
if (stateC != prevstateC) {
servo_moveC();
prevstateC = stateC;
if (stateD != prevstateD) {
servo_moveD();
prevstateD = stateD;
server.handleClient();
Thanks for taking a look.
Johnny
