Servo for Duemilanove
Hello everyone!
We're student working with a project and we have some trouble with getting our servo work with the board. It won't respond on our commands and programs though it's not broken. We just have some major problem to figure out the commands.
Can anyone help us out?
Thanks!
how do you have it hooked up, how are you powering the servo, please post your code, and how are you sure the servo is correctly working?
Have a look for zoomkat's servo test sketch. It gets posted fairly regularly.
The usual servo test code:
// zoomkat 10-4-10 serial servo test
// type servo position 0 to 180 in serial monitor
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-21"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(1);
    if (Serial.available() >0) {
      char c = Serial.read();  //gets one byte from serial buffer
      readString += c; //makes the string readString
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n;
    char carray[6]; //converting string to number
    readString.toCharArray(carray, sizeof(carray));
    n = atoi(carray);
    myservo.writeMicroseconds(n); // for microseconds
    //myservo.write(n); //for degees 0-180
    readString="";
