Servo glitches
Hi there. I have a servo that's going to be turning an ultrasonic sensor on my robot once the sensor detects an object is close. It is meant to turn turn 90 degrees to one way, 90 to the other, then come back to the center. The problem is, It glitches quite often by turning one way then staying there. Or it will turn one way and struggle to get back to the center position while making a small clicking sound. Other times it works the way it should. any ideas?
#include <Servo.h>
Servo myservo;
int pos=0;
int trigPin=3;
int echoPin=2;
int leftmf=10;
int leftmb=11;
int rightmf=8;
int rightmb=9;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(13, OUTPUT);
  pinMode(leftmf, OUTPUT);
  pinMode(leftmb, OUTPUT);
  pinMode(rightmf, OUTPUT);
  pinMode(rightmb, OUTPUT);
  digitalWrite(trigPin, LOW);
  myservo.attach(4);
  digitalWrite(rightmf, HIGH);
  digitalWrite(rightmb, LOW);
  digitalWrite(leftmf, HIGH);
  digitalWrite(leftmb, LOW);
  int duration, distance;
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH, 32760);
  distance=(duration/2) / 29.1;
  Serial.print(distance);
  Serial.println("cm");
  delay(10);
  if (distance<20)
    digitalWrite(rightmf, LOW);
    digitalWrite(leftmf, LOW);
    digitalWrite(13, HIGH);
    for (pos=90; pos<180; pos+=1)
      myservo.write(pos);
      delay(5);
int leftdistance;
  delayMicroseconds(15);
  leftdistance=(duration/2) / 29.1;
  Serial.print("left distance=");
  Serial.println(leftdistance);
    for (pos=180; pos>=1; pos-=1)
      myservo.write(pos);
      delay(5);
 int rightdistance;
  rightdistance=(duration/2) / 29.1;
    Serial.print("right distance=");
    Serial.println(rightdistance);
    for(pos=0; pos<=90; pos+=1)
      myservo.write(pos);
      delay(5);
    if (rightdistance>leftdistance);
    digitalWrite(rightmb, HIGH);
    digitalWrite(leftmb, HIGH);
    digitalWrite(13, LOW);
Are you powering the servo properly ?
Or, your program has a logical error.
Try writing a simple sketch that just makes the servo go backwards and forwards. That will establish that the servos work.
After you have tested that, then test your complicated scheme.
