Servo.h attach function
Hello
I'm currently using the servo library on a MEGA2560-board to control several brushless motors.
When I was reading through the information about the servo library it says
Attach the Servo variable to a pin. Note that in Arduino 0016 and earlier, the Servo library supports only servos on only two pins: 9 and 10.
from http://arduino.cc/de/Reference/ServoAttach#.U0ZvHhaYndk
But in other code, several servos were attached to the library/board.
#include <Servo.h>
// Sample sketch for driving 12 Servos from an Arduino UNO,
servos are attached to digital pins 2,3,4,5,6,7,8,9,10,11,12,13
#define CONNECTED_SERVOS 12
Servo myServos[CONNECTED_SERVOS];
  // attach the servos
  for(int nServo = 0;nServo < CONNECTED_SERVOS;nServo++)
    myServos[nServo].attach(SERVO_TO_PIN(nServo));
the code has been cut.
So at which Pins can I now actually connect brushless motors while using the Servo.h library?
Thank you for your answer
Did you READ the note? It says that the pins you can use depend on the version of the IDE you are using. 0016 was released years ago. If you are using anything close to modern, you can attach a servo to any unused pin.
The modern Servo library will work on any pin supporting digitalWrite().
Ok thank you.
I wasn't familiar with the version of the IDE
