servo has limited range
hello,
i have two servos, JX PDI-2506MG, that can only be driven between ~45° and ~135°
makes a rapid clicking when attempting to drive past these values.(guess: motor is oscillating to hold position)
mechanically it is capable of doing ~0° to ~180°.
i'm testing with the stock sweep sketch,it is producing the correct timings.(confirmed by scope)
a known servo,a JX 6632MG, in parallel works as expected.
internal pot appears to give approximately correct values for various angles.
any ideas?
The specification says that's a programmable servo. So I guess it's been programmed for only +/- 45 degrees. Unfortunately since I've never seen one of those servos I don't know how you go about reprogramming it.
Steve
thanks Steve.
dump for future reference:
the servo uses a KC9806 ic which is programmable
however the datasheet makes no mention to the protocol.
it is supposed to be programmable using a EMAX configuration card, according to
https://www.rcgroups.com/forums/showthread.php?2840779-F3P-Team-Finland-tips-and-tricks
datasheet attached
kc9806E.pdf (175 KB)
