Is that a space after the (9 ) and (8 )?.... not sure if it would make a difference though?
And when you say it "isn't working", what does that actually mean? What are you expecting to happen, and what actually happens?
Are you expecting the vehicle to move forward?- cos each time it does the write in loop() it stays where it is since the value hasn't changed. If I understand servoes correctly, the value is an absolute position, not an increment.
The use of "wheel" and "servo" leads me to suspect these are continuous rotation ex-servos.
Finding the "stop" position can be tricky, and it may be better to use the writeMicroseconds method for finer control.
Have a look for some of zoomkat's servo control sketches.
Servo test code you can try to make sure your servos are set up correctly.
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7); //the pin for the servo control
Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
readString=""; //empty for next input
