servo help :/?
hi, i am very new to arduinos. i did once build a PWM speed controller using one for my lathe motor but had found a thread where someone was doing the exact same project so i was able to just copy the code and it worked luckily haha.
ive gone back to basics and am trying to control a servo and every time i compile the code its fine then i try to upload it and get the following error message...
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 2064 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 50 bytes (2%) of dynamic memory, leaving 1998 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\Sophie\AppData\Local\Temp\arduino_build_352257/sketch_jan17a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\.\COM6": Access is denied.
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in C:\Users\Sophie\Documents\Arduino\libraries\hardware: no headers files (.h) found in C:\Users\Sophie\Documents\Arduino\libraries\hardware
option enabled in File -> Preferences.
this is the code i am running....
#include <Servo.h>
Servo myservo;
myservo.attach(9,600,2300);
myservo.write(0);
myservo.write(90);
myservo.write(135);
myservo.write(180);
my IDE is 1.8.12
any advise would be greatly appreciated :slight_smile:
just tried out the example 'blink' sketch and had the following message.....
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\Sophie\AppData\Local\Temp\arduino_build_266667/Blink.ino.hex:i
Using Port : COM6
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\Sophie\AppData\Local\Temp\arduino_build_266667/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.18s
avrdude: 924 bytes of flash written
avrdude: verifying flash memory against C:\Users\Sophie\AppData\Local\Temp\arduino_build_266667/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Sophie\AppData\Local\Temp\arduino_build_266667/Blink.ino.hex:
avrdude: input file C:\Users\Sophie\AppData\Local\Temp\arduino_build_266667/Blink.ino.hex contains 924 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: stk500_recv(): programmer is not responding
######avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
the selected serial port
does not exist or your board is not connected
the COM port most definitely exists and it is definitely connected does anyone have any suggestions?
@higgins420
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
very sorry about that just realized i posted in the wrong place :confused:
You are probably in a good place for now but you may want to learn HOW to post code and add schematics as they can be crucial.
Bob.
