Servo help
Hey, I tried to make a code where pressing a button makes a servo go right, and pressing another button makes it go left. The servo just spins left, right, waits a second, and loops. Any help?
#include <Servo.h>
int left = LOW;
int right = LOW;
int pos = 0;
Servo first;
  first.attach(9);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  left = digitalRead(11);
  right = digitalRead(12);
  if (left = HIGH)
    while (left == HIGH)
    left == digitalRead(11);
    pos++;
    first.write(pos);
  if (right = HIGH)
    while (right == HIGH)
    right == digitalRead(12);
    pos--;
    first.write(pos);
Make sure you have an external power supply for the servo, and the external power supply ground is connected to the arduino ground. Below is some button type test code.
//zoomkat servo button test 12-29-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
int button2 = 5; //button pin, connect to ground to move servo
int press2 = 0;
Servo servo1;
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  servo1.attach(7);
  digitalWrite(4, HIGH); //enable pullups to make pin high
  digitalWrite(5, HIGH); //enable pullups to make pin high
  press1 = digitalRead(button1);
  if (press1 == LOW)
    servo1.write(170);
  press2 = digitalRead(button2);
  if (press2 == LOW)
    servo1.write(10);
  /*else {
    servo1.write(90);
right = HIGH
Is always going to be true.
You need to pay more attention to assignments and comparisons
Thanks for the help guys! It's working great now.
