Servo is vibrating when rotating
Code taken from Bob (miniPanTileTest)
* Program Name: miniPanTileTest
* Author: Bob
* Cycle pan and tilt through a range of motions
* based upon  BARRAGAN <http://barraganstudio.com>
* and Scott Fitzgerald http://www.arduino.cc/en/Tutorial/Sweep
* Change History
* Date         Ver    Description
* 02/25/2019   V1.0   Initial development
#include <Servo.h>
Servo pan;    // create servo object to control the yaw servo
Servo tilt;  // create servo object to control the pitch servo
 *  setup()
 *  Called once at power on
  Serial.println("");
  pan.attach(9);   // attaches the servo on pin 12 to the servo object
  tilt.attach(8);  // attaches the servo on pin 13 to the servo object
 *  loop()
 *  Main processing loop. Called after setup()
  /*Check left/right and center movement*/
  Serial.println("Pan Control");
  for(int i=90;  i<180; i++) { pan.write(i); delay(25); }
  for(int i=180; i>0;   i--) { pan.write(i); delay(25); }
  for(int i=0;   i<90;  i++) { pan.write(i); delay(25); }
  /*Check up/down and center movement*/
  Serial.println("Tilt Control");
  for(int i=90;  i<145; i++) { tilt.write(i); delay(25); }
  for(int i=145; i>10;   i--) { tilt.write(i); delay(25); }
  for(int i=10;   i<90;  i++) { tilt.write(i); delay(25); }
  /*Move both servos at the same time(ish)*/
  int pmin=10;  //right
  int pmax=170; //left
  int ppos=90;  //current position
  int pinc=1;   //movement increment in degrees
  int tmin=10;  //top
  int tmax=145; //bot
  int tpos=90;  //current position
  int tinc=3;   //movement increment in degrees
  /*go through cycle twice */
  Serial.println("Dual Control");
  for(int i=0; i<(180*2); i++) {
    ppos += pinc;                           //increment to next position
    if(ppos > pmax) {ppos=pmax; pinc = -1;} //check for limit, change direction if necessary
    if(ppos < pmin) {ppos=pmin; pinc = 1;}  //check for limit, change direction if necessary
    tpos += tinc;                           //increment to next position
    if(tpos > tmax) {tpos=tmax; tinc = -3;} //check for limit, change direction if necessary
    if(tpos < tmin) {tpos=tmin; tinc = 3;}  //check for limit, change direction if necessary
    pan.write(ppos);  //move servo
    delay(20);
    tilt.write(tpos); //move other servo
    delay(20);        //some delay
  /*set pan/tilt to center */
  for(int i=ppos;  i!=90; i+=(ppos < 90 ? 1 : -1)) { pan.write(i); delay(25); }
  for(int i=tpos;  i!=90; i+=(tpos < 90 ? 1 : -1)) { tilt.write(i); delay(25); }
  delay(10000); //wait 10 seconds and do again
