Hi all,
I'm trying to control a servo when my Arduino UNO R3 wakes up from an interrupt on pin 2, but the servo starts jumping around when it is in rest. I copy-pasted "sketch J" from Nick Gammon's website: Gammon Forum : Electronics : Microprocessors : Power saving techniques for microprocessors, removed the LED part and attached a servo instead. As soon as the myservo.attach(10) code is implemented and a LED is connected to pin 10, it starts blinking every second (servo jitter). When a servo command is placed in the void loop the led starts blinking much faster.
Example:
#include <avr/sleep.h>
#include <Servo.h>
Servo myservo;
void wake ()
// cancel sleep as a precaution
sleep_disable();
// must do this as the pin will probably stay low for a while
detachInterrupt (0);
} // end of wake
void setup ()
{myservo.attach(10);
digitalWrite (2, HIGH); // enable pull-up
} // end of setup
void loop ()
{ // disable ADC
ADCSRA = 0;
set_sleep_mode (SLEEP_MODE_PWR_DOWN);
sleep_enable();
// Do not interrupt before we go to sleep, or the
// ISR will detach interrupts and we won't wake.
noInterrupts ();
// will be called when pin D2 goes low
attachInterrupt (0, wake, LOW);
// turn off brown-out enable in software
// BODS must be set to one and BODSE must be set to zero within four clock cycles
MCUCR = bit (BODS) | bit (BODSE);
// The BODS bit is automatically cleared after three clock cycles
MCUCR = bit (BODS);
// We are guaranteed that the sleep_cpu call will be done
// as the processor executes the next instruction after
// interrupts are turned on.
interrupts (); // one cycle
sleep_cpu (); // one cycle
} // end of loop
How to solve this?
Thanks!
