Servo LED Speed Multiplier
Hey everyone!
First time posting on the forum, I’m just a 3D Printer / Prop builder, but I’m trying to dabble into adding electronics and I just have a couple questions that hopefully someone can help me with. I’ve attached the code down below ( Tutorial’d ) with some edits.
What I’m looking to do :
  • I’m wondering if when the Servo is travelling to it’s 110 increment, if I can put a speed multiplier to the leds , hopefully I can specify which ones )
If anyone could help me that would be wicked!
#include <Servo.h>
class Flasher
  // Class Member Variables
  // These are initialized at startup
  int ledPin;      // the number of the LED pin
  long OnTime;     // milliseconds of on-time
  long OffTime;    // milliseconds of off-time
  // These maintain the current state
  int ledState;                 // ledState used to set the LED
  unsigned long previousMillis;   // will store last time LED was updated
  // Constructor - creates a Flasher
  // and initializes the member variables and state
  public:
  Flasher(int pin, long on, long off)
  ledPin = pin;
  pinMode(ledPin, OUTPUT);
  OnTime = on;
  OffTime = off;
  ledState = LOW;
  previousMillis = 0;
  void Update()
    // check to see if it's time to change the state of the LED
    if((ledState == HIGH) && (currentMillis - previousMillis >= OnTime))
      ledState = LOW;  // Turn it off
      previousMillis = currentMillis;  // Remember the time
      digitalWrite(ledPin, ledState);  // Update the actual LED
    else if ((ledState == LOW) && (currentMillis - previousMillis >= OffTime))
      ledState = HIGH;  // turn it on
class Sweeper
  Servo servo;              // the servo
  int pos;              // current servo position
  int increment;        // increment to move for each interval
  int  updateInterval;      // interval between updates
  unsigned long lastUpdate; // last update of position
public:
  Sweeper(int interval)
    updateInterval = interval;
    increment = 1;
  void Attach(int pin)
    servo.attach(pin);
  void Detach()
    servo.detach();
  void Update()
    if((millis() - lastUpdate) > updateInterval)  // time to update
      lastUpdate = millis();
      pos += increment;
      servo.write(pos);
      Serial.println(pos);
      if ((pos >= 105) || (pos <= 0)) // end of sweep
        // reverse direction
        increment = -increment;
Flasher led1(11, 250, 250);
Flasher led2(12, 0, 0);
Flasher led3(13, 250, 252);
Sweeper sweeper1(15);
Sweeper sweeper2(25);
  sweeper1.Attach(9); // SERVO PIN
  sweeper2.Attach(10);
  sweeper2.Update();
  if(digitalRead(2) == HIGH)  // IF BUTTON IS PUSHED ON PIN 2 , KEEP THESE SEQUENCES RUNNING TEMPORARILY
     sweeper1.Update();
     sweeper2.Update();
     led1.Update();
  led2.Update(); // THE NORMAL SEQUENCES
  led3.Update();
There are the two variables that control how long the light is on or off. I guess you could just modify those as needed to make the leds blink at whatever speed you'd like.
I guess the question is, how could I tell the Arduino to modify the timer based on the Servo’s position? I’m not really a coder so this has stumped me.
Thanks!
That’s an awfully complicated object oriented code for a noob. Maybe it would do you good to work on something simpler to start out.
Either way your Sweeper class holds the servo position in a variable named pos. Just write some if statements to look at that and calculate the intervals. Or if there is a mathematical relationship then write a line that does that math and sticks the result where you want it.
