Hallo,
ich habe einen arduino nano und würde gerne einen flyghtcontroller für meinen vtol machen
mein code ist wie folgt:
#include <Wire.h>
#include <Servo.h>
int throttle;
int aileron;
int elevator;
int rudder;
int tilt;
Servo throttleleftoutput;
Servo throttlerightoutput;
Servo tiltservooutput1;
Servo tiltservooutput2;
int throttleleft;
int throttleright;
int tiltservoleft;
int tiltservoright;
//Gyro Variables
float elapsedTime, time, timePrev; //Variables for time control
int gyro_error=0; //We use this variable to only calculate once the gyro data error
float Gyr_rawX, Gyr_rawY, Gyr_rawZ; //Here we store the raw data read
float Gyro_angle_x, Gyro_angle_y; //Here we store the angle value obtained with Gyro data
float Gyro_raw_error_x, Gyro_raw_error_y; //Here we store the initial gyro data error
//Acc Variables
int acc_error=0; //We use this variable to only calculate once the Acc data error
float rad_to_deg = 180/3.141592654; //This value is for pasing from radians to degrees values
float Acc_rawX, Acc_rawY, Acc_rawZ; //Here we store the raw data read
float Acc_angle_x, Acc_angle_y; //Here we store the angle value obtained with Acc data
float Acc_angle_error_x, Acc_angle_error_y; //Here we store the initial Acc data error
float Total_angle_x, Total_angle_y;
pinMode (8, INPUT);
pinMode (2, INPUT);
pinMode (5, INPUT);
pinMode (6, INPUT);
pinMode (7, INPUT);
throttleleftoutput.attach(9); // throttleleft
throttlerightoutput.attach(10); // throttleright
tiltservooutput1.attach(11); // tiltservo
tiltservooutput2.attach(3); // tiltservo
Wire.begin(); //begin the wire comunication
Wire.beginTransmission(0x68); //begin, Send the slave adress (in this case 68)
Wire.write(0x6B); //make the reset (place a 0 into the 6B register)
Wire.write(0x00);
Wire.endTransmission(true); //end the transmission
//Gyro config
Wire.write(0x1B); //We want to write to the GYRO_CONFIG register (1B hex)
Wire.write(0x10); //Set the register bits as 00010000 (1000dps full scale)
Wire.endTransmission(true); //End the transmission with the gyro
//Acc config
Wire.beginTransmission(0x68); //Start communication with the address found during search.
Wire.write(0x1C); //We want to write to the ACCEL_CONFIG register
Wire.write(0x10); //Set the register bits as 00010000 (+/- 8g full scale range)
Serial.begin(9600); //Remember to set this same baud rate to the serial monitor
time = millis(); //Start counting time in milliseconds
if(acc_error==0)
for(int a=0; a<200; a++)
Wire.write(0x3B); //Ask for the 0x3B register- correspond to AcX
Wire.endTransmission(false);
Wire.requestFrom(0x68,6,true);
Acc_rawX=(Wire.read()<<8|Wire.read())/4096.0 ; //each value needs two registres
Acc_rawY=(Wire.read()<<8|Wire.read())/4096.0 ;
Acc_rawZ=(Wire.read()<<8|Wire.read())/4096.0 ;
/*---X---*/
Acc_angle_error_x = Acc_angle_error_x + ((atan((Acc_rawY)/sqrt(pow((Acc_rawX),2) + pow((Acc_rawZ),2)))*rad_to_deg));
/*---Y---*/
Acc_angle_error_y = Acc_angle_error_y + ((atan(-1*(Acc_rawX)/sqrt(pow((Acc_rawY),2) + pow((Acc_rawZ),2)))*rad_to_deg));
if(a==199)
Acc_angle_error_x = Acc_angle_error_x/200;
Acc_angle_error_y = Acc_angle_error_y/200;
acc_error=1;
}//end of acc error calculation
if(gyro_error==0)
for(int i=0; i<200; i++)
Wire.write(0x43); //First adress of the Gyro data
Wire.requestFrom(0x68,4,true); //We ask for just 4 registers
Gyr_rawX=Wire.read()<<8|Wire.read(); //Once again we shif and sum
Gyr_rawY=Wire.read()<<8|Wire.read();
/*---X---*/
Gyro_raw_error_x = Gyro_raw_error_x + (Gyr_rawX/32.8);
/*---Y---*/
Gyro_raw_error_y = Gyro_raw_error_y + (Gyr_rawY/32.8);
if(i==199)
Gyro_raw_error_x = Gyro_raw_error_x/200;
Gyro_raw_error_y = Gyro_raw_error_y/200;
gyro_error=1;
}//end of gyro error calculation
}//end of setup void
aileron = pulseIn(8,HIGH);
elevator = pulseIn(7,HIGH);
throttle = pulseIn(6,HIGH);
rudder = pulseIn(5,HIGH);
tilt = pulseIn(2,HIGH);
aileron=constrain(aileron,1000,2000);
elevator=constrain(elevator,1000,2000);
throttle=constrain(throttle,1000,2000);
rudder=constrain(rudder,1000,2000);
tilt=constrain(tilt,1000,2000);
///////////////////////////////only vertical MIXING///////////////////////////////////////////////////////
aileron =aileron -1500;
elevator =elevator -1500;
throttle =throttle -1500;
rudder =rudder -1500;
throttleleft = constrain(throttle+throttle *(map(aileron,-500,500,-40,40)-
Total_angle_x)/90,-500,500)+1500;
throttleright = constrain(throttle-throttle *(map(aileron,-500,500,-40,40)-
tiltservoleft = 1500 + (1500* (map(elevator,-500,500,-20,20)+Total_angle_y)/200)-rudder/6;
tiltservoright = 1500 + (1500* (map(elevator,-500,500,-20,20)+Total_angle_y)/200)+rudder/6;
Serial.println(tiltservoleft);
Serial.println(tiltservoright);
Serial.println(throttleleft);
Serial.println(throttleright);
throttleleftoutput.writeMicroseconds(throttleleft);
throttlerightoutput.writeMicroseconds(throttleright);
tiltservooutput1.writeMicroseconds(throttleleft);
tiltservooutput2.writeMicroseconds(throttleright);
den code für den mpu6050 hab ich rausgeschnitten da sonst der code zu lange war aber die Kommunikation funktioniert und das Mixing ist auch kein problem, aber bei
habe ich ein problem weil er mir kein servo signal ausgibt, die on time ist immer 0.5 statt 1-2
throttleleft und die anderen variablien sind aber zwischen 1000 und 2000.
Wenn ich nur z.b 1500 reinschreibe ist mein servosignal wieder bei 1,5
hat jemand eine idee?
