does anyone know if the servo library works well on 8MHz (e.g., mini pro 3.3v) modules? does the updates still happen every 20ms ?
i'm asking because, my servos exhibit these spontaneous glitches every several seconds, which i suspect have something to do with the arduino update signal. when i unplug the servo's control wire from the arduino - these glitches - stop.. does it sound familiar to anyone?
Do some more searching around on the forum - I remember someone seeing similar "glitches" at normal speed; I can't recall what the issue turned out to be, though...
This is assuming you are using a separate power supply for your servos, of course, rated for the expected amperage of the servos (in the worse case scenario of all servos turning under load).
