servo library for Uno Wifi Rev2
Recently, I switched from Uno to Uno Wifi rev2. I use Servo library 1.1.3 working good with UNO but bad on Wifi Rev2.
My servo has jolts, random position jumps. I saw, using a scope, that pulses provided by UNO Wifi Rev2 are good 95% of time but bad 5% of time.
Switching back to UNO, pulses duration is constant.
An idea ?
Dan
Sketch is :
#include <Servo.h>
Servo my_servo;
my_servo.attach(2, 550, 2250); // D2 pin used
delay(10);
Serial.println(" ");
Serial.println("Uno_test");
while (true)
mon_servo.write(1429);
delay(100);
I made test with Atmega328 emulation and none (Atmega4809) emulation : same issue.
Dan
i would like to know who is supporting the servo library for Uno Rev2. What is the official procedure to report an issue ? thanks for your help.
Dan
kock:
Arduino is.
kock:
Make sure to provide enough information in your issue report so that the problem can be quickly reproduced by the people investigating it. When applicable, you should provide a Minimal, Complete, Verifiable Example sketch that will reproduce the issue.
