Servo library issue
Hi guys,
I attached my code. It is an obstacle avoiding robot car which is control by L298N driver. The issues are as follows
1: if I control the enable pins of the driver and also write the code about servo motor then motor does not spin and the only servo works
2: If I remove servo lines from the code then motor start spinning as they should be.
3: if I do not control enable pins of the driver with PWM and connect it with directly high signal in the circuit then both servo and motor works.
Now I must have to use enable pins to control the speed of the robot car. I also need to rotate the servo during the motion to detect the obstacle. Plz, help me to solve this issue. Thanks
#include <Servo.h>          //Servo motor library. This is standard library
#include <NewPing.h>        //Ultrasonic sensor function library. You must install this library
//our L298N control pins
#define EnablePinRight 9
#define EnablePinLeft 10
const int LeftMotorForward = 5;
const int LeftMotorBackward = 4;
const int RightMotorForward = 2;
const int RightMotorBackward = 3;
//sensor pins
#define trig_pin A0 //analog input 1
#define echo_pin A1 //analog input 2
#define maximum_distance 200
boolean goesForward = false;
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
void setup(){
  pinMode(RightMotorForward, OUTPUT);
  pinMode(LeftMotorForward, OUTPUT);
  pinMode(LeftMotorBackward, OUTPUT);
  pinMode(RightMotorBackward, OUTPUT);
  pinMode(EnablePinRight,OUTPUT);
  pinMode(EnablePinLeft,OUTPUT);
  servo_motor.attach(11); //our servo pin
  servo_motor.write(90);
  delay(2000);
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  int distanceRight = 0;
  int distanceLeft = 0;
  delay(50);
  if (distance <= 20)
    moveStop();
    delay(300);
    moveBackward();
    delay(400);
    moveStop();
    delay(300);
    distanceRight = lookRight();
    delay(300);
    distanceLeft = lookLeft();
    delay(300);
    if (distance >= distanceLeft){
      turnRight();
      moveStop();
    else{
      turnLeft();
      moveStop();
  else{
    moveForward();
int lookRight(){
  servo_motor.write(10);
  int distance = readPing();
  delay(100);
  return distance;
int lookLeft(){
  servo_motor.write(170);
  delay(100);
  return distance;
  delay(100);
int readPing(){
  delay(70);
  int cm = sonar.ping_cm();
  if (cm==0){
    cm=250;
  return cm;
void moveStop(){
  analogWrite(EnablePinRight, 0);
  analogWrite(EnablePinLeft,0);
  digitalWrite(RightMotorForward, LOW);
  digitalWrite(LeftMotorForward, LOW);
  digitalWrite(RightMotorBackward, LOW);
  digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
  if(!goesForward){
    goesForward=true;
    analogWrite(EnablePinRight, 85);
    analogWrite(EnablePinLeft,65);
    digitalWrite(LeftMotorForward, HIGH);
    digitalWrite(RightMotorForward, HIGH);
void moveBackward(){
  goesForward=false;
  digitalWrite(LeftMotorBackward, HIGH);
  digitalWrite(RightMotorBackward, HIGH);
void turnRight(){
void turnLeft(){
Note this
On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins
in Servo - Arduino Reference
