servo library not working
// Sweep
// by BARRAGAN http://barraganstudio.com
// This example code is in the public domain.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp: In member function 'uint8_t Servo::attach(int)':
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp:28: error: 'digitalWrite' was not declared in this scope
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp:29: error: 'OUTPUT' was not declared in this scope
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp:29: error: 'pinMode' was not declared in this scope
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp: In member function 'void Servo::write(int)':
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp:52: error: 'clockCyclesPerMicrosecond' was not declared in this scope
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp: In static member function 'static void Servo::refresh()':
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp:74: error: 'millis' was not declared in this scope
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp:107: error: 'digitalWrite' was not declared in this scope
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp:109: error: 'TCNT0' was not declared in this scope
/Users/admin/Documents/Arduino/libraries/Servo/Servo.cpp:124: error: 'digitalWrite' was not declared in this scope
hope you can help and thanks
