Servo Library TimerOne Library Conflict
Hi Gang
I've been working on a project using the Servo library in conjunction with the TimerOne library but I'm not having much luck. It appears the two libraries don't like one another. Am I correct in thinking that the reason for this is that they both share Timer 1? If this is the case, is the solution to simply use TimerThree library or is it not quite that simple?
Cheers
Jase :)
No its because they can't share timer 1.
Only if it exists - which arduino are you using.
Mark
Hi holmes4
Thanks for getting back to me. I am currently using an Arduino Uno.
TimerThree Library
Cheers
Jase :)
There is also a ServoTimer2 library.
...R
