Hi All,
I'm making a camera tilt using a servo and an IR receiver... The code I'm using is working well, but I would like to limit the servo form going past certain degrees. For example I need it to operate between 75-110 degrees. I would be very grateful if someone could help with this. Thanks!
Her is my code
/* Version 1.0 Jan 2015 - Credit to groundfungus
* "IR_Servo" Control a servo using an IR remote
#include <IRremote.h>
#include <Servo.h>
const byte RECV_PIN = 2;
IRrecv irrecv(RECV_PIN);
Servo myservo;
byte position = 110; // range = 75-110
boolean newIRdata = false;
unsigned long IRinput;
decode_results results;
myservo.attach(9);
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results))
IRinput = results.value;
irrecv.resume(); // Receive the next value
newIRdata = true;
if(newIRdata == true)
Serial.println(IRinput, HEX);
switch(IRinput)
// move right 5 degrees per button push
case(0xA3C8EDDB): // right arrow
position-=5;
Serial.println(position);
// move left 5 degrees per button push
case(0x511DBB): // left arrow
position+=5;
// go to 110
case(0x20FE4DBB): // up arrow
position = 110;
// go to 75
case(0x52A3D41F): // down arrow
position = 75;
IRinput = 0;
newIRdata = false;
myservo.write(position);
