Servo/Linear Actuator Code troubleshooting
I am fairly new to the Arduino world and need help with an issue with a code that I have written to control a servo and a linear actuator.
Background/function:
The servo and the linear actuator are independently controlled via two momentary switches.
Both the servo and the linear actuator are coded to go to a set parameter (angle or distance) with a push of the button and then return with a subsequent push of the button.
Servo is a Parallax Servo
Linear Actuator is a Actuonix P-16-P series connected to an Actuonix LAC board.
If I upload the codes independently (one to just control the servo or one to just control the linear actuator) the code works perfectly.
When I try to fuse the two codes together only the servo is functioning and I cannot get any response from the linear actuator.
I have ran verification on the code and do not get any errors.
Any help with this would be greatly appreciated.
P.S. I apologize if this is in the wrong category or if my code does not display properly.
[table][tr][tt][size=0.8em]Code: see how to post code [/size][/tt][hr][/tr][tr][tt][size=0.8em]#include[nobbc] <[/nobbc]Servo[nobbc].h>[/nobbc]
#include[nobbc] <Bounce2.h>[/nobbc]
[nobbc]//defines[/nobbc]
[nobbc][/nobbc]Servo[nobbc] myservo; [/nobbc][nobbc]// create servo object to control expansion servo[/nobbc]
[nobbc][/nobbc]Servo[nobbc] LINEARACTUATOR; [/nobbc][nobbc]// create servo objects to control the linear actuator[/nobbc]
const int[nobbc] LINEAR_ACTUATOR_PIN = 5; [/nobbc][nobbc]//Linear Actuator Digital Pin[/nobbc]
const int[nobbc] BUTTON_PIN = 4; [/nobbc][nobbc]// the number of the pushbutton pin[/nobbc]
[nobbc]// variables will change:[/nobbc]
int[nobbc] buttonState = 0; [/nobbc][nobbc]// variable for reading the pushbutton status for the servo[/nobbc]
int[nobbc] linearValue = 1000; [/nobbc][nobbc]// current positional value being sent to the linear actuator. [/nobbc]
[nobbc]Bounce debouncer = Bounce(); [/nobbc][nobbc]// debouncing object for linear actuator push button[/nobbc]
#define[nobbc] servoPin 3 [/nobbc][nobbc]//~ PWM for servo[/nobbc]
#define[nobbc] ButtonSPin 2 [/nobbc][nobbc]//input button for expansion servo[/nobbc]
int[nobbc] ButtonSState = 0;[/nobbc]
int[nobbc] buttonSPushed = 0;[/nobbc]
int[nobbc] angle =0; [/nobbc][nobbc]// initial angle for servo[/nobbc]
int[nobbc] angleStep =30;[/nobbc]
const int[nobbc] minAngle = 0;[/nobbc]
const int[nobbc] maxAngle = 90;[/nobbc]
void setupnobbc {[/nobbc]
[nobbc] myservo.[/nobbc]writenobbc;[/nobbc]
[nobbc] myservo.[/nobbc]attachnobbc; [/nobbc][nobbc]// attaches the servo on pin 3 to the servo object[/nobbc]
pinModenobbc; [/nobbc]
[nobbc]//initialize servo/linear actuator objects[/nobbc]
[nobbc] LINEARACTUATOR.[/nobbc]attach[nobbc](LINEAR_ACTUATOR_PIN, 1000, 1500); [/nobbc][nobbc]// attaches/activates the linear actuator as a servo object [/nobbc]
[nobbc]// initialize the pushbutton pin as an input with internal pullup:[/nobbc]
pinMode[nobbc](BUTTON_PIN, [/nobbc]INPUT_PULLUP[nobbc]); [/nobbc]
[nobbc]// After setting up the button, setup the Bounce instance:[/nobbc]
[nobbc] debouncer.[/nobbc]attachnobbc;[/nobbc]
[nobbc] debouncer.interval(5); [/nobbc][nobbc]// interval in ms[/nobbc]
[nobbc]//use the writeMicroseconds to set the linear actuators to their default positions[/nobbc]
[nobbc] LINEARACTUATOR.[/nobbc]writeMicrosecondsnobbc; [/nobbc]
void loopnobbc {[/nobbc]
[nobbc]//servo control[/nobbc]
if(digitalReadnobbc == [/nobbc]LOW[nobbc]){[/nobbc]
buttonSPushed = 1;
ifnobbc{[/nobbc]
[nobbc]// change the angle for next time through the loop:[/nobbc]
angle = angle + angleStep;
[color=#434F54][nobbc]// reverse the direction of the moving at the ends of the angle:[/nobbc][/color]
[color=#5E6D03]if[/color][nobbc] (angle <= minAngle || angle >= maxAngle) {[/nobbc]
  angleStep = -angleStep;
   buttonSPushed = 0;
[nobbc] myservo.[/nobbc]writenobbc; [/nobbc][nobbc]// move the servo to desired angle[/nobbc]
delaynobbc; [/nobbc][nobbc]// waits for the servo to get there[/nobbc]
[nobbc]//LA Control[/nobbc]
[nobbc]// Update the Bounce instance :[/nobbc]
debouncer.update();
[nobbc]// Get the updated value :[/nobbc]
int[nobbc] buttonValue = debouncer.[/nobbc]readnobbc;[/nobbc]
if[nobbc] ( debouncer.fell() ) [/nobbc][nobbc]// if the button was pressed[/nobbc]
if[nobbc] (linearValue == 1000) [/nobbc][nobbc]//if the box is set to close[/nobbc]
[nobbc] linearValue = 1500; [/nobbc][nobbc]//set box to open[/nobbc]
else if[nobbc] (linearValue == 1500) [/nobbc][nobbc]//if the box was set to open[/nobbc]
[nobbc] linearValue = 1000; [/nobbc][nobbc]//set box to close[/nobbc]
}[/size][/tt][/tr][/table]
Trying to fix the code...
#include <Servo.h>
#include <Bounce2.h>
//defines
Servo myservo;  // create servo object to control expansion servo
const int LINEAR_ACTUATOR_PIN = 5;        //Linear Actuator Digital Pin
const int BUTTON_PIN = 4;     // the number of the pushbutton pin
int buttonState = 0;         // variable for reading the pushbutton status
Servo LINEARACTUATOR;  // create servo objects to control the linear actuator
int linearValue = 1000;   // current positional value being sent to the linear actuator.
Bounce debouncer = Bounce(); // debouncing object
#define servoPin 3 //~ PWM for servo
#define ButtonSPin 2 //input button for expansion servo
int ButtonSState = 0;
int buttonSPushed = 0;
int angle =0;    // initial angle  for servo
int angleStep =30;
const int minAngle = 0;
const int maxAngle = 90;
  myservo.write(0);
  myservo.attach(servoPin);  // attaches the servo on pin 3 to the servo object
  pinMode(ButtonSPin,INPUT_PULLUP);
  LINEARACTUATOR.attach(LINEAR_ACTUATOR_PIN, 1000, 1500);      // attaches/activates the linear actuator as a servo object
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  debouncer.attach(BUTTON_PIN);
  debouncer.interval(5); // interval in ms
  LINEARACTUATOR.writeMicroseconds(linearValue);
//servo control
  if(digitalRead(ButtonSPin) == LOW){
    buttonSPushed = 1;
   if( buttonSPushed ){
    if (angle <= minAngle || angle >= maxAngle) {
       buttonSPushed = 0;
    myservo.write(angle); // move the servo to desired angle
    delay(100); // waits for the servo to get there
//LA Control
  debouncer.update();
  int buttonValue = debouncer.read();
  if ( debouncer.fell() ) // if the button was pressed
    if (linearValue == 1000) //if the box is set to close
      linearValue = 1500; //set box to open
    else if (linearValue == 1500) //if the box was set to open
      linearValue = 1000; //set box to close
Your code changes linearvalue when the button is pressed but it doesn't use it on the actuator.
Isn't that the point of this line?
I'm not sure I understand your statement.
See below the linear actuator code that does work by itself. I merely copied it into the servo code that also worked by itself.
//Includes
#include <Servo.h> //Servo Library
#include <Bounce2.h> //Debouncing Library
//Defines
  debouncer.update();
  LINEARACTUATOR.writeMicroseconds(linearValue); //use the writeMicroseconds to set the actuator to the new position
It looks like you didn't post all your code in post #2. I don't see the end of the loop function.
There it is! Thank you sir. I knew it had to be something little like that. Probably me staring at a computer too long.
This may be more than you need, but who knows:
Simultaneous Control of Multiple Servos
Thank you for taking the time to reply. Wildbill was correct. I missed the last line in my code when I copied and pasted from my notepad to Arduino IDE.
