Servo locking up
I'm using an Arduino Due to rotate a servo when a code is entered into a 4x3 matrix keypad. I've tried both a Parallax continuous rotation servo, and a Futaba S3003, but neither work correctly. The continuous rotation simply turns endlessly, and twitches when the code is entered, and the other servo locks in a specific position, and twitches when the code is entered. I'd very much appreciate some assistance! It's almost certainly a software issue, as the servos work properly when run on Arduino's servo test program.
#include <Keypad.h>
#include <Servo.h>
Servo servo_Motor;
char* password = "123";
int position = 0;
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = { 11, 6, 7, 9 };
byte colPins[COLS] = { 10, 12, 8 };
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int redPin = 12;
int greenPin = 13;
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
servo_Motor.attach(13);
setLocked(true);
char key = keypad.getKey();
if (key == '*' || key == '#')
position = 0;
setLocked(true);
if (key == password[position])
position ++;
if (position == 3)
setLocked(false);
delay(100);
void setLocked(int locked)
if (locked)
digitalWrite(redPin, HIGH);
digitalWrite(greenPin, LOW);
servo_Motor.write(90);
digitalWrite(redPin, LOW);
digitalWrite(greenPin, HIGH);
I can't help but notice that the locked and (presumably) unlocked positions are the same - 90 "degrees"
Please use code tags when posting code.
Thank you!!! I knew the internet could find all my dumb errors :smiley:
