Servo Motor (1 cycle)
Hi guys, i would like to design a code whereby the servo motor [rotates 90 deg forward and rotate back in reverse 90 degree(initial position) ] when the Arduino magnetic contact switch door is closed. i only want this cycle to happen one time until the switch is open and close again next time. for now im facing a issue where by servo rotates forward and reverse nonstop when the switch is in contact.
#include <Servo.h>
Servo myservo;
int LED1 = 8;
int LED = 9;
const int sensor = 12;
int myservo_position = 0;
int doorState;
myservo.attach(13);
pinMode(sensor, INPUT_PULLUP);
pinMode(LED, OUTPUT);
pinMode(LED1, OUTPUT);
myservo.write(myservo_position);
return ;
doorState = digitalRead(sensor);
if (doorState == LOW)
digitalWrite(LED1, LOW);
digitalWrite(LED, HIGH);
delay (1000);
myservo.write(90);
delay (1000);
digitalWrite(LED, LOW);
delay (500);
digitalWrite(LED1, HIGH);
Have a look at the state change detect tutorial.
