Servo motor 360 degrees
hello everybody
i'm using a servo motor who can rotate 360 degrees.
my question is: how can I stop it from rotating.
for example, it needs to rotate to 36 degrees en then it needs to stop.
hopefully someone cal help me
thank you
You don't say exactly what "servo" you have but most things called 360 degree servos aren't really servos any more. They have NO positional control at all. They are also called continuous rotation servos which is more accurate.
You can only make them rotate forward or backward and to some extent their speed but NOT control where they stop or the amount they rotate.
Steve
If you have a continuous rotation servo then you cannot control its position - only the direction and speed.
If you need a servo that allows 360° of motion with position control then consider a sail winch servo - they can turn about 3 revolutions with position control.
...R
Depending on the load to be attached either the advice above or a simple stepper motor with a switch to mark the 360 point.
