Servo Motor and Magnetic Sensor Coding Assistance.
Hello everyone!
I have undergone a seemingly simple project, and have hit a snag. Currently, this code,
#include <Servo.h>
const int red = 13;
const int Switch = 7;
const int servo = 8;
Servo Serv1;
int angle = 0;
int maxi = 95;
        pinMode(red, OUTPUT);
        pinMode(Switch, INPUT_PULLUP);
        Serv1.attach(servo);
        int SwitchState = digitalRead(Switch);
        if (SwitchState == HIGH)
          digitalWrite(red, HIGH);
          Serv1.write(38);
          delay(250);
            digitalWrite(red, LOW);
            Serv1.write(90);
            delay(15);
has been rotating a servo from 90 to 38 when the magnetic sensor becomes separated. The servo rotating to 38, presses a space bar to play and pause a video. Currently the code will pause the video when the magnet loses contact, although I would like it to play the video once the magnet has lost contact and regained contact.
I feel as if this should be as simple as the rest of the code, but I have had 0 luck. I would really appreciate some help.
Thank you!
Use a "falling edge trigger" such as:
byte pastState = 0;
byte currentState = 0;
loop()
   pastState = currentState;
   if(digitalRead(pin))
      currentState = 1;
      currentState = 0;
   if((currentState == 0) && (pastState == 1))
      servo.write(38);
      servo.write(90);
I really appreciate the help! I put in that code, the way that I thought it would work. Not quite there. I must have done it wrong. Currently, the servo is set off only after the magnet is disconnected and then connected.
#include <Servo.h>
const int red = 13;
Servo Serv1;
int angle = 0;
int maxi = 95;
byte pastState = 0;
          currentState = 1;
          currentState = 0;
          Serv1.write(38);
          delay(250);
            Serv1.write(90);
            delay(15);
jonner13: I must have done it wrong. Currently, the servo is set off only after the magnet is disconnected and then connected.
But isn't that what you wanted it to do?
jonner13: I would like it to play the video once the magnet has lost contact and regained contact.
