servo motor and switchpin
Hi! I'm making my first program and I need your help. I want to control 2 continuous rotation servo motor with 2 switch. First, can I stop those motor? I'm trying everything to make them stop and it's not working.
Can someone help me with the code!? For exemple, if I press the switch #1, the motor 2 will make a complete rotation. If I press the switch 2, only the second motor will works.
Thanks for you help!
You can stop them, but not at a certain position if that's what you mean. So to make it do a complete rotation and stop back at the position it started at, is not possible without some more stuff like an encoder.
Basically once a servo is a continuous servo, it stops being a servo: you sacrifice position control for direction and speed control.
Audep1: Hi! I'm making my first program and I need your help. I want to control 2 continuous rotation servo motor with 2 switch. First, can I stop those motor? I'm trying everything to make them stop and it's not working.
As JimboZA says, you can't make a continuous-rotation servo do exactly one turn.
To stop a continuous-rotation servo, using the "Servo" library, you write a 90 to it. e.g.
servo.write(90);
OldSteve: To stop a continuous-rotation servo, using the "Servo" library, you write a 90 to it.
In theory.... Although I've never used one, apparently the exact stopping value can be somewhere between say 88 and 92. I believe some such servos have an adjusting screw so you can make it stop at exactly 90.
JimboZA:
In theory… Although I’ve never used one, apparently the exact stopping value can be somewhere between say 88 and 92.
Yep, you’re spot on. I was just thinking that I should maybe add that info. Thanks for saving me the trouble. :slight_smile:
Right again. (Two of the servos sitting here now have trim screws, and two don’t.)
