servo motor code issue
Hey im having an issue with my servo motor code. im trying to make a robotic arm so i need the motor to move in increments and not a sweeping motion. My code currently does increments for the motor in one direction and a sweep in the other direction.
    int i;
    unsigned char data, addr;
    // Command to send to the gamecube
    // The last bit is rumble, flip it to rumble
    // yes this does need to be inside the loop, the
    // array gets mutilated when it goes through N64_send
    unsigned char command[] = {0x01};
    // don't want interrupts getting in the way
    noInterrupts();
    // send those 3 bytes
    N64_send(command, 1);
    // read in data and dump it to N64_raw_dump
    N64_get();
    // end of time sensitive code
    interrupts();
    // translate the data in N64_raw_dump to something useful
    translate_raw_data();
   for (i=0; i<16; i++) {
       Serial.print(N64_raw_dump[i], BIN);
    Serial.print(' ');
    Serial.print(N64_status.stick_x, BIN);
    Serial.print(' ');
    Serial.print(N64_status.stick_y, BIN);
    Serial.print(" \n");
   //   Serial.print("         Stick X:");
 //   Serial.print(N64_status.stick_x, BIN);
  //  Serial.print("         Stick Y:");
//Serial.println(N64_status.stick_y, BIN);
      if (N64_status.data1 == 0) {
      controlServoy();
      controlServox();
      controlServoy2();
      controlServox2();
    //If any of the fcllowing buttons A,B,Z,Start are pushed then it unlocks control for servo 3 and 4
      if (N64_status.stick_x >0)
        N64_status.stick_y =0
      ;if (N64_status.stick_y >0)
        N64_status.stick_x =0
    // DEBUG: print it
    //print_N64_status();
    delay(25);
void controlServox() {
  if (N64_status.stick_x > 10 && currentServoPosition >=0)
  currentServoPosition = currentServoPosition - 45; //can change the number to make it move quicker
 else if (N64_status.stick_x > 90 && currentServoPosition >= 0){
  //Do nothing the servo is already at its max
 else if (N64_status.stick_x < -10 && currentServoPosition < 180){
  currentServoPosition = currentServoPosition +  10; //can change the number to make it move quicker
 else if (N64_status.stick_x < -10 && currentServoPosition >= 180){
 else{
  //Do nothing Stick is roughly centre
 myservo.write(currentServoPosition);
void controlServoy() {
  if (N64_status.stick_y > 10 && currentServoPosition1 >=0)
  currentServoPosition1 = currentServoPosition1 - 90; //can change the number to make it move quicker
 else if (N64_status.stick_y > 90 && currentServoPosition1 >= 0){
 else if (N64_status.stick_y < -10 && currentServoPosition1 < 180){
  currentServoPosition1 = currentServoPosition1 +  10; //can change the number to make it move quicker
 else if (N64_status.stick_y < -10 && currentServoPosition1 >= 180){
 else{
 myservo1.write(currentServoPosition1);
void controlServox2() {
  if (N64_status.stick_x > 10 && currentServoPosition2 >=0)
  currentServoPosition2 = currentServoPosition2 - 180; //can change the number to make it move quicker
 else if (N64_status.stick_x > 90 && currentServoPosition2 >= 0){
 else if (N64_status.stick_x < -10 && currentServoPosition2 < 180){
  currentServoPosition2 = currentServoPosition2 +  10; //can change the number to make it move quicker
 else if (N64_status.stick_x < -10 && currentServoPosition2 >= 180){
 else{
 myservo2.write(currentServoPosition2);
void controlServoy2() {
  if (N64_status.stick_y > 10 && currentServoPosition3 >=0)
  currentServoPosition3 = currentServoPosition3 - 90; //can change the number to make it move quicker
 else if (N64_status.stick_y > 90 && currentServoPosition3 >= 0){
 else if (N64_status.stick_y < -10 && currentServoPosition3 < 180){
  currentServoPosition3 = currentServoPosition3 +  10; //can change the number to make it move quicker
 else if (N64_status.stick_y < -10 && currentServoPosition3 >= 180){
 else{
 myservo3.write(currentServoPosition3);
It is very difficult to see where your code actually moves the servos - can you isolate that code into a function so it is clearer?
...R
 else{
there is the code for one of the 4 servo motors
You can change the number to make it move slower - smaller number.
