servo motor control by A.UNO and Node MCU (Blynk Local Server)
Hello Guyz ,
I am doing my project on dual axis solar Tracker with two servo motor,4 LDR to take light as input to direct servos ,arduino,nodemcu,Blynk local server
It works fine individually with only arduino servos and ldr (ln this motors are connected to arduino and control with ldr inputs )
It works fine Individually with node mcu blynk local server as i can control both motor with app
(in this mototrs are connected to node mcu and controlled with blynk app )
everything work fine
But what is want is
i want to control motor with natural input from ldr to arduino and also from blynk app
what should i do ???
here is my sketches
1.Arduino sketch
#include <Servo.h>
// 180 horizontal MAX
Servo horizontal; // horizontal servo
int servoh = 180; // 90; // stand horizontal servo
int servohLimitHigh = 180;
int servohLimitLow = 0;
// 65 degrees MAX
Servo vertical; // vertical servo
int servov = 45; // 90; // stand vertical servo
int servovLimitHigh = 80;
int servovLimitLow = 15;
// LDR pin connections
// name = analogpin;
int ldrlt = 0; //LDR top left - BOTTOM LEFT <--- BDG
int ldrrt = 1; //LDR top rigt - BOTTOM RIGHT
int ldrld = 2; //LDR down left - TOP LEFT
int ldrrd = 3; //ldr down rigt - TOP RIGHT
{ Serial.begin(9600);
// servo connections
// name.attacht(pin);
horizontal.attach(9);
vertical.attach(10);
horizontal.write(180);
vertical.write(45);
delay(3000);
{ int lt = analogRead(ldrlt); // top left
int rt = analogRead(ldrrt); // top right
int ld = analogRead(ldrld); // down left
int rd = analogRead(ldrrd); // down right
// int dtime = analogRead(4)/20; // read potentiometers
// int tol = analogRead(5)/4;
int dtime = 10; int tol = 50;
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and rigt
/*Serial.print("Bottom Left");
Serial.print(" ");
Serial.print(lt);
Serial.print(" ");
Serial.print("Bottom Right ");
Serial.print(" ");
Serial.print(rt);
Serial.print(" ");
Serial.print("Top Left");
Serial.print(" ");
Serial.print(ld);
Serial.print(" ");
Serial.print("Top Right ");
Serial.print(" ");
Serial.print(rd);
Serial.print(" ");
if (-1*tol > dvert || dvert > tol) // check if the diffirence is in the tolerance else change vertical angle
if (avt > avd)
servov = ++servov;
if (servov > servovLimitHigh)
servov = servovLimitHigh;
else if (avt < avd)
servov= --servov;
if (servov < servovLimitLow)
servov = servovLimitLow;
vertical.write(servov);
if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr)
servoh = --servoh;
if (servoh < servohLimitLow)
servoh = servohLimitLow;
else if (avl < avr)
servoh = ++servoh;
if (servoh > servohLimitHigh)
servoh = servohLimitHigh;
else if (avl = avr)
// nothing
horizontal.write(servoh);
delay(dtime);
2.Node MCU Sketch
#include <ESP8266WiFi.h>
#define BLYNK_PRINT Serial
#include<Servo.h>
#include <BlynkSimpleEsp8266.h>
char auth[] = "VwKQeYeZPYh9Ec2bD2poMfK_XC4wywiy";
char ssid[] = "S";
char pass[] = "";
Servo s1;
Servo s2;
 Blynk.begin(auth, ssid, pass);
  // You can also specify server:
  //Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, ssid, pass, IPAddress(192,168,0,103), 8080);
  s1.attach(15);//D8
  s2.attach(02);//D4
  Blynk.run();
BLYNK_WRITE(V1)
 s1.write(param.asInt());
BLYNK_WRITE(V2)
 s2.write(param.asInt());
** i have one idea but i dont know how to inmplent it with hardware **
i tried connecting servo signal pin one at a time
first connected to arduino it works normal with natural ldr inputs
second i disconnect servo signal pin from arduino and connect to node mcu pin according to my pin diagram it works with blynk app
here my idea is to add switch like hardware part so that i dont have to connect and disconnect it everytime from both boards
please suggest an implenetation relation to this idea if any
Thank You!!!
If this were my project, I would use only the nodeMCU, I would not use a second Arduino. But nodeMCU has only one analog pin, and not many digital pins. So I would use either an analog multiplexer or an ads1115 to provide 4 analog channels.
sry but i dont have programming knowledge about multiplexer
I'm sorry too. I thought you wanted suggestions. I would not suggest using Uno and nodeMCU together, it is much more complex than using a multiplexer.
"sry but i dont have programming knowledge about multiplexer"
Multiplex chips are fairly simple chips that usually have 8 inputs that can be switched to one output, which is connected to the arduino analog input pin. I think 74HC4067 AND 74HC4051 are examples.
