Servo Motor Control using bluetooth and ultra sonic sensor
I am doing a school project where I am making a Smart dustbin that can open its lid using a servo motor by an ultra-sonic sensor and Bluetooth module. but only the bluetooth part is working. kindly help me right my code.
code:
#include <SoftwareSerial.h>
#include <Servo.h>
Servo myServo;
int pos = 0;
const int trigPin = 5;
const int echoPin = 6;
const int led = 13;
long duration;
float distance;
int TxD = 11;
int RxD = 10;
int servoposition;
int servopos;
int new1;
SoftwareSerial bluetooth(TxD, RxD);
  Servo myservo;
  int pos = 0;
  myServo.attach(9);
  myServo.write(0);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(led, OUTPUT);
  myservo.write(pos);
  Serial.begin(9600);       // start serial communication at 9600bps
  bluetooth.begin(9600);
  { Servo myservo;
    //Serial.begin(9600);
    digitalWrite(trigPin, LOW);
    delayMicroseconds(2);
    digitalWrite(trigPin, HIGH);
    delayMicroseconds(10);
    duration = pulseIn(echoPin, HIGH);
    distance = 0.034 * (duration / 2);
    //Serial.println(distance);
    if (distance < 27)
      digitalWrite(led, HIGH);
      myservo.write(pos + 180);
      digitalWrite(led, LOW);
      myservo.write(pos);
    delay(300);
  if (bluetooth.available())
    String value = bluetooth.readString();
    servoposition = value.toInt();
    if (value.toInt() == 0)
      Serial.println(servoposition);
      myServo.write(0);
    if (value.toInt() == 45)
      myServo.write(45);
    if (value.toInt() == 90)
      myServo.write(90);
    if (value.toInt() == 135)
      myServo.write(135);
    if (value.toInt() == 180)
      myServo.write(180);
    while (value.toInt() == 1) {
        Serial.println(value);
        if (value.toInt() == 2)
          Serial.println("YYY");
      servopos++;
      delay(30);
      Serial.println(servopos);
      myServo.write(servopos);
      if (servopos == 180 )
        servopos = 0;
"Right" is very old-fashioned; normally we'd say "correct".
Please remember to use code tags when posting code.
Maybe try using the IDE's auto-format tool to see what's wrong
Auto-format is showing no errors. thanks anyways
Maybe you could post the result anyway- it makes it easier to read your code - it's very badly formatted as it is now.
this is the code for servo motor control using Bluetooth module:
#include <Servo.h>
Servo myServo;
int TxD = 11;
int RxD = 10;
int servoposition;
int servopos;
int new1;
  int pos=0;
  myServo.attach(9);
  myServo.write(0);
    myServo.write(0);
    myServo.write(45);
    myServo.write(90);
    myServo.write(135);
    myServo.write(180);
   while(value.toInt()==1){
    if (value.toInt()==2)
    {Serial.println("YYY");  break; }
    servopos++;
    delay(30);
    if (servopos ==180 )
    {servopos=0;break;}
and this is the code for servo motor control using ultra sonic sensor:
#include <Servo.h>
Servo myservo;
int pos =0;
const int led = 13;
long duration;
float distance;
  myservo.attach(9);
  myservo.write(pos);
  distance = 0.034*(duration/2);
  if (distance < 27)
    digitalWrite(led,HIGH);
    myservo.write(pos+180);
    digitalWrite(led,LOW);
      myservo.write(pos);
  delay(300);
both codes work perfectly on their own, I need to combine these 2 functions for my project.
The instantiation of myservo i.e. "Servo myservo;" should NOT be repeated in setup() and loop(). It should only be in one place, where it is in the working code.
There may be other errors but fix that first and post the new version of your combined code.
Steve
Hi
I tested your code here with minor modifications and the US part worked correctly.
It only has a very large delay when the distance is less than 27.
To test both BT and US, and since I don't have a BT module,
I changed the BT lines to use the serial.
And again everything worked correctly.
#include <Servo.h>
Servo myServo;
int pos = 0;
const int led = 13;
long duration;
float distance;
int TxD = 11;
int RxD = 10;
int servoposition;
int servopos;
int new1;
  Servo myservo;
  int pos = 0;
  myServo.attach(9);
  myServo.write(0);
  myservo.write(pos);  // ????
  Servo myservo;
  if (distance < 27)
    //myservo.write(pos + 180);  // ????
    myservo.write(180);
    delay(1000);   // high delay is necessary ????
  Serial.println("Servo180");
    myservo.write(pos);
    Serial.println("Servo0");
  delay(300);
//   if(Serial.available())
    //String value = Serial.readString();
      myServo.write(0);
      myServo.write(45);
      myServo.write(90);
      myServo.write(135);
      myServo.write(180);
      //if (Serial.available())
        //value = Serial.readString();
      servopos++;
      delay(30);
        servopos = 0;
Serial monitor printout:
57
58
59
60
61
62
63
64
65
66
67
2
YYY
Servo0
Servo0
Servo0
Servo0
Servo0
Servo0
Servo0
Servo0
Servo0
Servo0
Servo0
Servo0
Servo0
Servo180
Servo180
Servo180
Servo180
Servo180
Servo180
Servo0
Servo0
Servo0
Servo0
the servo motor still doesn't operate when the code is uploaded
then the compiler says that myservo was not declared in this scope.
anyways this is the new code after removing my servo from the setup and loop
#include <Servo.h>
Servo myServo;
int pos = 0;
const int led = 13;
long duration;
float distance;
int TxD = 11;
int RxD = 10;
int servoposition;
int servopos;
int new1;
  int pos = 0;
  myServo.attach(9);
  myServo.write(0);
  myservo.write(pos);
    if (distance < 27)
      myservo.write(pos);
    delay(300);
      myServo.write(0);
      myServo.write(45);
      myServo.write(90);
      myServo.write(135);
      myServo.write(180);
      servopos++;
      delay(30);
        servopos = 0;
C++ is case-sensitive.
could it be the case that both modules are using pin 9 to send signal to servo moto
I'm sorry, I don't understand the question
