servo motor error
when i try below program for servo motor getting error kindly help to solve the issue
//add the servo library
//# include <servo.h>
//define our servos
Servo servo1;
//Servo servo2;
//define joystick pins (Analog)
int joyx = 0;
int joyy = 1;
//variable to read the values from the analog pains
int joyval;
//attaches our servos on pins PWM 3-5
servo1.attach(3);
//servo2.attach(5);
Void loop ()
//read the value of joystick(between 0-1023)
Joyval = analogRead (joyX);
Joyval = map(joyval, 0, 1023, 0, 180);//servo value between 0-100
servo1.write(joyval);//set the servo position according to the joystick value
Joyval = analogRead(joyy);
joyval = map (joyval, 0, 1023, 0, 180);
//servo2.write(joyval);
delay(15);
error code below
Arduino: 1.8.3 (Windows 7), Board: “Arduino/Genuino Uno”
sketch_dec03a:7: error: ‘Servo’ does not name a type
Servo servo1;
sketch_dec03a:20: error: ‘Void’ does not name a type
Void loop ()
C:\Users\halmajid\Desktop\sketch_dec03a\sketch_dec03a.ino: In function ‘void setup()’:
sketch_dec03a:17: error: ‘servo1’ was not declared in this scope
servo1.attach(3);
C:\Users\halmajid\Desktop\sketch_dec03a\sketch_dec03a.ino: At global scope:
Void loop ()
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
//# include <servo.h>oops
Please remember to use code tags when posting code
And C++ is case sensitive - void and Void are not the same thing nor are servo and Servo.
Steve
