Servo Motor - Full Rotation
How can I use Arduino to control the Full Rotational Servo Motor to let it only rotate 180?
Here is my code, can any one help me to troubleshoot it? hservo is using 360 degree servo motor, but I only want it to turn a bit.
#define BOTTOM 1
#define TOP 0
#define RIGHT 2
#define LEFT 3
#define CENTRE 4
#include <Servo.h>
#include "math.h"
Servo hservo;
Servo vservo;
int topsense;
int bottomsense;
int leftsense;
int rightsense;
int centresense;
int tavg;
int tavg1;
int diff;
int diff1;
int spd;
int spd1;
int divisor;
int sensitivity;
void setup ()
hservo.writeMicroseconds(1500);
vservo.attach(9);
hservo.attach(10); // attaches the servo on pin 10 to the servo object
divisor = 10; // this controls the speed of the servo. lower number = higher speed
sensitivity = 5; ; // this controls the sensitivity of the tracker. lower number = higher sensitivity. if your tracker is constantly jittering back and forth increase the number
pinMode(BOTTOM, INPUT); // set the inputs
pinMode(TOP, INPUT);
pinMode(LEFT, INPUT);
pinMode(RIGHT, INPUT);
pinMode(CENTRE, INPUT);
void loop ()
topsense = analogRead(TOP); // read the light sensors
bottomsense = analogRead(BOTTOM);
rightsense = analogRead(RIGHT);
leftsense = analogRead(LEFT);
centresense = analogRead(CENTRE);
tavg = (topsense + bottomsense)/2; // get an average value for the top 2 sensors
diff = abs(tavg - (centresense)); // this judges how far the tracker must turn
spd = diff/divisor; // and adjusts the speed of the reaction accordingly
spd = max(spd, 1); // sets the minimum speed to 1
tavg1 = (rightsense + leftsense)/2;
diff1 = abs(tavg1 - leftsense);
spd1 = diff1/divisor;
spd1 = max(spd1, 1);
if((rightsense < leftsense) && (diff > sensitivity))
{ // if the average value of the top sensors is smaller (more light) than the bottom sensor
vservo.write(90 - spd1); // send servo command to turn upward plus add speed
else if((rightsense > leftsense) && (diff > sensitivity))
{ // if the value of the bottom sensor is smaller (more light) than the average value of the top sensors and the tilt sensor is in the correct range
vservo.write(90 + spd1);
// send servo command to turn downward plus add speed
{ // for every other instance
vservo.write(90); // stop the y-axis motor
topsense = analogRead(TOP); // read the top 2 sensors again because they have probably changed
//trsense = trsense * 1.03; // again I had to adjust the value of one sensor to make the tracker more accurate
diff = abs(topsense - bottomsense); // reset the diff variable for the new values
spd = diff/divisor; // and generate a speed accordingly
spd = max(spd, 1); // set the minimum speed to 1
if((topsense < bottomsense) && (diff > sensitivity))
{ // if the top left sensor value is smaller (more light) than the top right sensor
if ( (90+spd)<110)
hservo.write(90 + spd); // send servo command to turn lef
hservo.write(90);
else if((topsense > bottomsense) && (diff > sensitivity))
hservo.write(90); // stop the x-axis motor
delay(10); // delay 10ms
If your "Full Rotational Servo Motor" is a servo modified for "continuous rotation", then your best option is to obtain a standard servo that is not modified.
zoomkat:
which means, I cannot only let it turn 45 degree, or 90, or 180?
RenYi_1993:
Correct, you can't. Once it's modified, and some members here then say it should not be called a servo anymore, the value you send which would position a "real" servo, now control the speed of a "continuous" servo.
JimboZA:
RenYi_1993:
But how can I know whether the servo has modified for "continuous rotation"?
Send it a few values with the servo library, servo.pos()
On a normal servo, 90 will take it to the midpoint, but on a continuous servo is a speed of 0. (Or in theory... it may be 88, 89, 90, 91 or 92, say.)
On a normal servo, 0 will go full position one way, but on a continuous servo will be full speed spinning in one direction.
On a normal servo, (90 edit error) 180 will go full position the other way, but on a continuous servo will be full speed spinning in the other direction.
JimboZA:
On a normal servo, 90 will go full position the other way, but on a continuous servo will be full speed spinning in the other direction.
I write servo.write(90); it will stop, but if the number is greater than 90, it will spin at one direction and less than 90 will go another direction. Hence, it shows this motor is continuous, isn't it?
Yeah...
(Sorry I just noticed my error in the previous post: should have been 180. I'm fixing it there.)
JimboZA:
Yeah...
It's Okay. Thank you very much?
