I am using TowerPro SG90 Servo Motor (180° Rotation) with ESP32. I got the motor to work in the desired way and it was okay for some time. Now the servo motor is not working and it is heating very fast. Please guide me with this problem.
Hello fathimaiqbal123
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
It is a simple circuit and i am using the example sweep code of esp32
#include <ESP32Servo.h>
//#define RELAY_PIN4 14
Servo myservo; // create servo object to control a servo
// 16 servo objects can be created on the ESP32
int pos = 0; // variable to store the servo position
// Recommended PWM GPIO pins on the ESP32 include 2,4,12-19,21-23,25-27,32-33
// Possible PWM GPIO pins on the ESP32-S2: 0(used by on-board button),1-17,18(used by on-board LED),19-21,26,33-42
//#if defined(ARDUINO_DOIT ESP32 DEVKIT V1)
int servoPin = 13;
// Allow allocation of all timers
ESP32PWM::allocateTimer(0);
ESP32PWM::allocateTimer(1);
ESP32PWM::allocateTimer(2);
ESP32PWM::allocateTimer(3);
//digitalWrite(RELAY_PIN4, HIGH);
//pinMode(RELAY_PIN4, OUTPUT);
myservo.setPeriodHertz(50); // standard 50 hz servo
myservo.attach(servoPin, 500, 2000); // attaches the servo on pin 18 to the servo object
// using default min/max of 1000us and 2000us
// different servos may require different min/max settings
// for an accurate 0 to 180 sweep
//digitalWrite(RELAY_PIN4, LOW); // turn on pump 2
//delay(6100);//6000
// digitalWrite(RELAY_PIN4, HIGH); // turn off pump 4 seconds
// delay(200);
// if(RELAY_PIN4== LOW){
for (pos = 0; pos <= 180; pos += 15) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(10); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 15) { // goes from 180 degrees to 0 degrees
From the SG90 datasheet, you'll need to use default min/max of 1000μs and 2000μs.
myservo.attach(servoPin, 1000, 2000);
but sir, earlier it was working according to the program. But now what will exactly be the reason.
I am just asking out of curiosity.
I'm guessing the incorrect min setting (500μs) caused overheating and it burned out over a period of time. Similar to this issue, except it was the code that was trying to change the servo position beyond its lower limit.
On another servo of same type, I suggest starting with
myservo.attach(servoPin, 1050, 1950);
Which might give 5 to 175 deg range. Then adjust to suit your application, but don't go beyond
as mentioned in the datasheet.
Hello @fathimaiqbal123
If your code is working fine then you have to check your hardware,check the pwm pulses from the esp 32 or just check your servo👍
