Servo Motor Initial Position (URGENT)
So I'm doing a robotic arm that has 4 servos. When I power on the breadboard and the arduino, the servos goes to a random position all of a sudden before starting the real code. I would like to remove this random positioning and I'm not sure how to do it.
This is the test code I'm using.
#include <Servo.h>
  Servo servo1,servo2,servo3,servo4;
void setup () {
servo1.attach(9);
servo2.attach(8);
servo3.attach(7);
servo4.attach(6);
void loop () {
  servo1.write(45);
  servo2.write(45);
  servo3.write(45);
  servo4.write(45);
  servo1.write(0);
  servo2.write(0);
  servo3.write(0);
  servo4.write(0);
If by "remove this random positioning" you mean that you want to specify the position that each servo starts in then just do a write(yourPos) immediately before each servo.attach().
BTW it's not actually random, it's the equivalent of doing a write(90) for each servo.
Steve
slipstick:
Steve
Thank you Steve, that worked beautifully.
Regards,
Bruno.
Just to be pedantic!
In this case it’s a servo, NOT a servo motor...
The servo has a motor inside ir -with feedback, but there are many types of servo/servo motor.
