servo motor jumping
I´m using a Arduino One board and a micro servo and the original “sweep code”.
The board is connected to the USB. Someone on the forum suggested to attach the servo to a separate 6 V and ground to the board ground - but the same problem.
My problem:
It runs OK during the 1st loop and the 2nd - but at the end of the 2nd and before the servo is going back it just “jumps up 5 degrees and back 5 degrees” before it goes back.
How can I avoid this little jump?
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
Thanks,
Goran
Servos do not, necessarily, go to 0 or to 180 degrees. You may need to, experimentally, determine the actual range of the servo an adjust your code accordingly.
First loop/second loop? Do you mean it goes from 0 to 180 then back from 180 to 0 and THEN it "jumps" before starting back towards 180?
I've never seen a servo do that but perhaps 0-180 is too much for whatever servo you're using. Try changing it to 5-175 or even 10-170.
Steve
Thanks everyone. I think I should explain little better next time.
Hi, Thank you "slipstick" and "GroundFungus".
That solved the problem - but I still dont know why.
The original code was: 0 to 180 degrees but since I only wanted 0 to 80 degrees I used those numbers but it didnt work.
So as you suggested: "try to some other values". I changed to 10 to 90 degrees - and it worked so well.
Many thanks, Goran
