This is the code that I'm trying to use. I'm not exactly sure if my issue is a code error or the servo itself. If you use servos then you can probably tell that I'm just trying to write my servo to 90 degrees so I can use it as a kind of baseline for another project. When I upload the code though, the servo makes a humming sound and when I touch it I can feel it vibrating slightly. No actual turning. If I give the arm that I attached to it a push in the direction that I want it to go, it will usually end up going on it's own the rest of the way.
This reads like it is a power problem.
Can you get a pen and paper, draw how you have everything wired up, take a picture of that drawing and post the picture here?
