Servo motor, LDR and LEDs
I am currently working on a project including an LDR, a servo motor and LEDS. I have written the code however, when I tried to combine them the LDR controlling the servo stopped working but the LEDs are working. Please can you help combine my code so that both things can happen simultaneously.
#include <Servo.h>
Servo myservo;
const int ldrpin = A0;
const int servopin = 8;
int ldrValue;
int angle = 0;
int LED1 = 13;
int LED2 = 12;
myservo.attach (servopin);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
ldrValue = analogRead(ldrpin);
angle = map (ldrValue, 0, 1023, 0, 270);
Serial.println(angle);
myservo.write (angle);
delay (15);
digitalWrite(LED1, HIGH);
delay(3000);
digitalWrite(LED2, LOW);
delay(3000);
digitalWrite(LED1,LOW);
delay(3000);
digitalWrite(LED2, HIGH);
delay(3000);
delay(3000);
delay(3000);
delay(3000);
delay(3000);
delay(3000);
delay(3000);
This portion of code does nothing but turn the LED on and off for 15 seconds during which time the LDR will not be read. Is that what you want ?
Look at Using millis() for timing. A beginners guide, Several things at the same time and look at the BlinkWithoutDelay example in the IDE.
Thank you for your response.
I would like the LDR to control the servo motor at the same time as the leds are on
lewis1706:
I think that much is obvious. Have you looked at the links provided? That's where you will find the solution.
Without all the useless delay()s, what does the code ACTUALLY do?
