Servo motor misbehaving when potentiometer is at zero
Hey everybody :slight_smile:
I have created the attached circuit and written the following code:
#include <Servo.h>
const int SERVO=9; //Servo on Pin 9
const int POT=0;    //POT on Analog Pin 0
Servo myServo;
int val = 0;     //for storing the reading from the POT
    myServo.attach(SERVO);
    val = analogRead(POT);           //Read Pot
    val = map(val, 0, 1023, 0, 179); //scale it to servo range
    myServo.write(val);              // sets the servo
    delay(15);                       // waits for the servo
It works really ok apart from when the potentiometer is at zero. Then, the servo starts spinning and stopping on its own. Any ideas?
Add a Serial.print() line so you can see what the value of the variable val actually is.
And. temporarily increase the delay(15) to delay(200);
...R
How big is your "9V battery"?
Thanks..Tom.. :slight_smile:
Yes, you may be hitting the endstop and pulling lots of current, and your supply is inadequate
(people always underestimate the current demand of servos and motors - they use lots of current,
small servos typically require 1A at 6V, and if you are using a small 9V battery it cannot possibly
supply that - they are completely unsuitable for motors)
