I have a servo motor and i think it's not working. How can i understand if it is working or not? My servo motor is: SM-S2309S.
I have connected it with an arduino uno and a joystick so i can control the servo motor with the joystick. Here is the code
#include <Servo.h>
// Define the pins for the joystick and servo
#define JOYSTICK_X A0
#define JOYSTICK_Y A1
#define SERVO_PIN 9
// Define the range of values for the joystick
#define JOYSTICK_MIN 0
#define JOYSTICK_MAX 1023
// Define the range of angles for the servo motor
#define ANGLE_MIN 0
#define ANGLE_MAX 180
// Define the angle increment
#define ANGLE_INCREMENT 5 // Adjust this value as needed
Servo servoMotor;
int currentAngle = 90; // Start from the center position
int lastJoystickX = JOYSTICK_MIN; // Initialize the last joystick position
// Initialize serial communication for debugging
// Attach the servo to its pin
servoMotor.attach(SERVO_PIN);
// Read the values from the joystick
int joystickX = analogRead(JOYSTICK_X);
// Only update the servo position if the joystick position has changed
if (joystickX != lastJoystickX) {
// Map the joystick values to the range of servo angles
int angleChange = map(joystickX, JOYSTICK_MIN, JOYSTICK_MAX, -ANGLE_INCREMENT, ANGLE_INCREMENT);
// Calculate the new angle
int newAngle = currentAngle + angleChange;
// Ensure the new angle is within the allowed range
if (newAngle < ANGLE_MIN) {
newAngle = ANGLE_MIN;
} else if (newAngle > ANGLE_MAX) {
newAngle = ANGLE_MAX;
// Update the servo position
servoMotor.write(newAngle);
// Update the current angle and last joystick position
currentAngle = newAngle;
lastJoystickX = joystickX;
// Print the joystick value and mapped angle for debugging
Serial.print("Joystick X: ");
Serial.print(joystickX);
Serial.print(", Angle Change: ");
Serial.print(angleChange);
Serial.print(", New Angle: ");
Serial.println(newAngle);
// Add a short delay to avoid reading the joystick too frequently
delay(50);
