I have a new 6221MG servo motor. it’s a larger servo with metal gears. its rated at 4.6 - 6 volts but i cant find info on how many amps it draws. will my uno feed enough amps through the 5 volt pin for this size servo or does it need a power supply?
An UNO feeds 20 mA, shortly 40 mA. You need drivers rated for what ever current being needed.
Railroader:
Those values are for the digital outputs, but the board itself can supply up to a few hundred mA.
Don’t use the Arduino to provide power for your servo.
The stall current of a "20Kg" servo is likely to be around 4A which is WAY MORE than the 5V pin can support. You definitely need an external power supply.
Steve
taterking:
I have a new 6221MG servo motor. it's a larger servo with metal gears. its rated at 4.6 - 6 volts but i cant find info on how many amps it draws. will my uno feed enough amps through the 5 volt pin for this size servo or does it need a power supply?
I power 3 20Kg 4.8-6.8V metal geared servos, 24/7 running a X/Y/Z platform with their own 7805 regulator; been running for almost a year.
In the past, I used a single regulator to run one servo and the ESP32 uController. That move cost me 2 ESP32's. Since putting the servo(s) on their own regulator no more burnt out ESP32's.
taterking:
Funny! I had no trouble finding this page which cites stall current at 1600mA, albeit at 5.2 V. At 6 V it might be nearer 2 Amps.
taterking:
The UNO - or any Arduino - is simply not some sort of power supply; you do not "feed" power through it.
It is most unfortunate that any purportedly "instructional" website might ever suggest such at concept but - well, this is the Internet, isn't it?
Idahowalker:
I am not sure what to say about that!
thanks you everyone. this is just the info i was looking for. I was looking for the amps that these things draw and peoples experiences with them. Idahowalker's comment was actually a very direct answer based on his expirience. I wanted to know if my servo would draw too many amps through my uno's on board voltage regulator before hooking up my servo to the 5 volt pin. anyways, i will be sure to get a sufficient external regulated power supply based on the amperage you guys mentioned. thanks again!
taterking:
I wanted to know if my servo would draw too many amps through my UNO's on board voltage regulator before hooking up my servo to the 5 volt pin.
That is the problem. It is particularly misleading for any website, "instructable" or tutorial to suggest that the on-board regulator is actually usable to provide power for anything other than the microprocessor itself and a few indicator LEDs drawing perhaps, 20 mA each. But there are websites, including this Arduino website's tutorials - which imply that you could.
And ...
TheMemberFormerlyKnownAsAWOL:
That is, when supplied not by the on-board regulator, but through the USB connector.
