Servo motor programming
what does "#include <Servo.h>" do in the programming. I think it may be a library to make it easier to move a servo. I refer particularly to this sketch;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int val;    // set val between 0-180 to move servo
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
Serial.print("input value for variable val: ");
while (Serial.available() == 0) {
val = Serial.parseInt();
Serial.print("val=");
Serial.println(val);
 myservo.write(val);
  delay(15);
You are correct.
The library defines the functions you will use to control the "myservo" object.
That is correct. Degrees are easily human readable, so someone wrote this library that will convert degrees into the necessary pulses required to move the servo.
Here is the same question with some very good responses and links:
https://forum.arduino.cc/t/servo-h-where-can-i-get-the-detail/1104627/2
