I have been trying to make hammers that strike on bells at every quarter of an hour. I got one TowerPro SG90 9G and it worked quite nicely, except for occasional sounds that motor was emitting, but they weren't too loud so I didn't mind. Then I got the second motor of same type, but it cannot be still. It is shaking and emitting loud sounds regularly. Not only that, when it is moving it is also shaking, making it impossible to strike nicely at the bell.
At first I thought that it was weight of the hammer causing it, but why doesn't the second motor have the same problem? And when its supposed to be still, I put it at 90 degree angle so that weight of the hammer is minimal and its still shaking. Not to mention that the hammer is made of few plastic lego cubes and one nut, nothing too heavy. Here is a video:
Could anyone please help me on this? Is the motor defective maybe? Thanks!
Sorry, I'm just a beginner and not used to making schematics yet.
Arduino is powered via USB since I am using a Java app to send the control signals.
What do you mean by "is the load sufficient for the supply?" I though I only have to watch that servos are not too powerful for the supply?
Terraviper-5:
An unregulated, or poorly regulated supply, can have a significantly higher than nominal voltage output if it's insufficiently loaded. Here's an explanation of why. Now most computer PSUs are built to do a decent job of DC regulation, but some cheaply constructed brands or old ones with degraded parts don't regulate the outputs well.
Hmm, never heard of that, interesting to know. Servos are rated for 3.0-7.2 Volts, and I am supplying 5V. Could this "effect" be the cause of my problem? I still don't understand though why the 1st motor, when it was powered alone on this same supply, was emitting sounds only occasionally, and those weren't loud. There was not trace of shaking. While this second one is totally useless.
I read on some forum that those servos were drawing 0.6 A current, so together those two would draw 1.2 A. But I assume they don't draw much when they are idle yes?
Terraviper-5:
You'd need to measure the voltage with a multimeter the at a point between the supply and the servos to be sure. However, unless you have a defective or cheaply made PSU the actual supple voltage will probably be under 7.2 Volts. As discussed below, the servos are going to be drawing some current even when the arms aren't moving.
Terraviper-5:
You have to remember just because a servo isn't moving it's not truly idle. The control logic is constantly updating the position and even a light weight arm will take a small but appeciable amount of force to keep balanced horizonatally (unless you spent an irrational amount of time and effort ensuring it was constructed to be near-perfectly balanced). Although you are right that it probably isn't going to be around 1.2 A, but the total current might be as high as 0.3 A to 0.4 A.
One other thing that occured to me, it could be the control board on your second servo isn't functioning properly. Have you tried disconnecting the first servo and just using the second one by itself?
I have checked the cables and they seem to be ok, although I am using a lot of different cables since I didnt have enough at home, put together to make 1 meter of a cable to be able to have my bells on the nearest wardrobe. Some of them are cheap shit, and I am using molex at the end to be able to use bridge cables for protoboard to be able to connect to servos as they have some special connector. It is possible that there is some crappy link in between. Will have to go and buy new quality cables.
I have measured the voltage and it was a little below 5, so that shouldnt be the cause of problems.
Far-seeker:
Terraviper-5:
Terraviper-5:
Yes, but its 200W power supply, I would have though that that's enough for 2 mini servos.
I guess that its possible that those arms are too much load for those two mini servos. I wasnt sure about it because 1st servo didnt shake.
Far-seeker:
Terraviper-5:
Yes, but its 200W power supply, I would have though that that’s enough for 2 mini servos.
Oh I didn’t mean the servos were trying to draw too much current! Instead, it was the possibility you were drawing too little with a poorly regulated supply and therefore getting a higher supply voltage than what the servos were rated for that I was wondering about. However, as previously stated if they really are rated for upto 7.2 VDC that that’s unlikely to be what’s going on. Still it wouldn’t hurt to check voltage under load, especially if the second servo performs well by itself.
Terraviper-5:
Even without the hammer it is still emitting buzzing sounds!
Unless I'm missing something it seems like the servo is moving properly on command. The sound is a little unexpected, but you previously mentioned some buzzing with your other servo. So the problem is unlikely to be a defective controller board on one of your servos.
Terraviper-5:
Far-seeker:
Still it wouldn't hurt to check voltage under load, especially if the second servo performs well by itself.
I did, it was under 5 volts (about 4.2 volts). Varying a little (+- 0.3), but no way over 5. Servo goes from 3.3 to 7.2.
The supplied voltage well within the operational ratings. Next you might want to want to put your multimeter in series and measure current (if it has more than one setting for current measurement make sure you use the one with the highest limit), both while being held vertical as well as while moving. After that, you can hook them both up and take similar measurement for the total current.
I suggest you try a different power supply. If you have a 200w power supply and the output voltage is down to 4.2v when powering a small servp, that sounds bad (note that some pc switching power supplys in the past needed a minimum of ~10% rated load or higher to be stable). Below is a simple 7805 regulator chip based setup with a diode on the chip ground to up the output voltage up to 5.7v for better servo performance.
both motors connected
both buzzing - 100 mA
one buzzing 10 to 50 mA
both moving - 280 to 300 mA
1st moving - 165 mA, sometimes just goes nuts (?? - never happened before), then 250 mA
2nd moving - 155 mA
both silent - 0 mA
1st obstructed and unable to move to default position - up to 500 mA +
1st motor connected
buzzing - to 20 mA
moving - 155 mA
2nd motor connected
moving - 155 mA
buzzing - to 10 mA
The second motor wasnt shaking (yet) today
Edit: Eh, now it did a little, but not so much as yesterday.
I just noticed the motor is buzzing a little if its connected to arduino ground but has otherwise no power.
zoomkat:
Thanks. But I also connected it to arduino uno directly and it was still shaking (second video). My computer was powered on and has 700W quality power supply.
You seem to be stuck in your own rut, so hope it works for you.
I just hope its the servos which are screwed up, not Arduino. I assume Arduino is still working properly (not fried) if servos are still obeying its commands? The thing that got me worried is buzzing (very silent) that was coming out of servos, even though the red (+) wire was not connected, only ground from Arduino and pwm from Arduino.
I tried another adaptor from old IomegaZip, it says 5 V DC, 1000 mA. That should be enough, but when I connected it the first time servos were like crazy, they were moving around totally out of control. Then I took everything apart and connected servos one by one with protoboard wires, then the servos were working, but still buzzing and shaking.
