Servo motor to Arduino Leonardo
I’m trying to connect 3 servo motors to the Arduino Leonardo and a MPU6050, im using this code, but when I go verificate it appears this error: ‘getYawPitchRollInDeg’ was not declared in this scope
The libraries im using are on this link: GitHub - jrowberg/i2cdevlib: I2C device library collection for AVR/Arduino or other C++-based MCUs
Im new to coding so i don´t understand very well the codes, so i would like if you could explain me why it is happening and what should I do.
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
MPU6050 mpu;
#define DEBUG
#ifdef DEBUG
//#define DPRINT(args...)  Serial.print(args)             //OR use the following syntax:
#define DPRINTSTIMER(t)    for (static unsigned long SpamTimer; (unsigned long)(millis() - SpamTimer) >= (t); SpamTimer = millis())
#define  DPRINTSFN(StrSize,Name,...) {char S[StrSize];Serial.print("\t");Serial.print(Name);Serial.print(" "); Serial.print(dtostrf((float)__VA_ARGS__ ,S));}//StringSize,Name,Variable,Spaces,Percision
#define DPRINTLN(...)      Serial.println(__VA_ARGS__)
#else
#define DPRINTSTIMER(t)    if(false)
#define DPRINTSFN(...)     //blank line
#define DPRINTLN(...)      //blank line
#endif
#define interruptPin 7
#define LED_PIN 13 //
// supply your own gyro offsets here, scaled for min sensitivity use MPU6050_calibration.ino
//                       XA      YA      ZA      XG      YG      ZG
//int MPUOffsets[6] = {    2471,   -563,   690,   66,     -29,     39}; //
//int MPUOffsets[6] = {1136, -44, 1047 , 52, 5, 26};// Test Board
int MPUOffsets[6] = {24288, -28144, 17392 , -163, -50, -50};// Test Board 9255
// ===                      i2c SETUP Items                     ===
void i2cSetup() {
  // join I2C bus (I2Cdev library doesn't do this automatically)
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
  Wire.begin();
  TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
  Fastwire::setup(400, true);
#endif
// ===               INTERRUPT DETECTION ROUTINE                ===
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
  mpuInterrupt = true;
// ===                      MPU DMP SETUP                       ===
int FifoAlive = 0; // tests if the interrupt is triggering
int IsAlive = -20;     // counts interrupt start at -20 to get 20+ good values before assuming connected
// MPU control/status vars
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
byte StartUP = 100; // lets get 100 readings from the MPU before we start trusting them (Bot is not trying to balance at this point it is just starting up.)
void MPU6050Connect() {
  static int MPUInitCntr = 0;
  // initialize device
  mpu.initialize(); // same
  // load and configure the DMP
  devStatus = mpu.dmpInitialize();// same
  if (devStatus != 0) {
    // ERROR!
    // 1 = initial memory load failed
    // 2 = DMP configuration updates failed
    // (if it's going to break, usually the code will be 1)
    char * StatStr[5] { "No Error", "initial memory load failed", "DMP configuration updates failed", "3", "4"};
    MPUInitCntr++;
    Serial.print(F("MPU connection Try #"));
    Serial.println(MPUInitCntr);
    Serial.print(F("DMP Initialization failed (code "));
    Serial.print(StatStr[devStatus]);
    Serial.println(F(")"));
    if (MPUInitCntr >= 10) return; //only try 10 times
    MPU6050Connect(); // Lets try again
    return;
  mpu.setXAccelOffset(MPUOffsets[0]);
  mpu.setYAccelOffset(MPUOffsets[1]);
  mpu.setZAccelOffset(MPUOffsets[2]);
  mpu.setXGyroOffset(MPUOffsets[3]);
  mpu.setYGyroOffset(MPUOffsets[4]);
  mpu.setZGyroOffset(MPUOffsets[5]);
  Serial.println(F("Enabling DMP..."));
  mpu.setDMPEnabled(true);
  // enable Arduino interrupt detection
  Serial.println(F("Enabling interrupt detection (Arduino external interrupt pin 2 on the Uno)..."));
  Serial.print("mpu.getInterruptDrive=  "); Serial.println(mpu.getInterruptDrive());
  attachInterrupt(digitalPinToInterrupt(interruptPin), dmpDataReady, RISING);
  mpuIntStatus = mpu.getIntStatus(); // Same
  // get expected DMP packet size for later comparison
  packetSize = mpu.dmpGetFIFOPacketSize();
  delay(1000); // Let it Stabalize
  mpu.resetFIFO(); // Clear fifo buffer
  mpu.getIntStatus();
  mpuInterrupt = false; // wait for next interrupt
// ===                    MPU DMP Get Data                      ===
void GetDMP() { // Best version I have made so far
  // Serial.println(F("FIFO interrupt at:"));
  // Serial.println(micros());
  static unsigned long LastGoodPacketTime;
  FifoAlive = 1;
  fifoCount = mpu.getFIFOCount();
  if ((!fifoCount) || (fifoCount % packetSize)) { // we have failed Reset and wait till next time!
    digitalWrite(LED_PIN, LOW); // lets turn off the blinking light so we can see we are failing.
    mpu.resetFIFO();// clear the buffer and start over
    while (fifoCount  >= packetSize) { // Get the packets until we have the latest!
      mpu.getFIFOBytes(fifoBuffer, packetSize); // lets do the magic and get the data
      fifoCount -= packetSize;
    LastGoodPacketTime = millis();
    MPUMath(); // <<<<<<<<<<<<<<<<<<<<<<<<<<<< On success MPUMath() <<<<<<<<<<<<<<<<<<<
    digitalWrite(LED_PIN, !digitalRead(LED_PIN)); // Blink the Light
// ===                        MPU Math                          ===
float Yaw, Pitch, Roll;
void MPUMath() {
  mpu.dmpGetQuaternion(&q, fifoBuffer);
  mpu.dmpGetGravity(&gravity, &q);
  mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
  Yaw = (ypr[0] * 180.0 / M_PI);
  Pitch = (ypr[1] *  180.0 / M_PI);
  Roll = (ypr[2] *  180.0 / M_PI);
  getYawPitchRollInDeg(ypr, &q, &gravity);
  DPRINTSTIMER(100) {
    DPRINTSFN(15, " W:", q.w, -6, 4);
    DPRINTSFN(15, " X:", q.x, -6, 4);
    DPRINTSFN(15, " Y:", q.y, -6, 4);
    DPRINTSFN(15, " Z:", q.z, -6, 4);
    DPRINTSFN(15, " Yaw:", Yaw, -6, 2);
    DPRINTSFN(15, " Pitch:", Pitch, -6, 2);
    DPRINTSFN(15, " Roll:", Roll, -6, 2);
    DPRINTSFN(15, " Yaw:", ypr[0], -6, 2);
    DPRINTSFN(15, " Pitch:", ypr[1], -6, 2);
    DPRINTSFN(15, " Roll:", ypr[2], -6, 2);
    DPRINTLN();
// ===                         Setup                            ===
  Serial.begin(115200); //115200
  while (!Serial);
  Serial.println("i2cSetup");
  i2cSetup();
  Serial.println("MPU6050Connect");
  MPU6050Connect();
  Serial.println("Setup complete");
  pinMode(LED_PIN, OUTPUT);
// ===                          Loop                            ===
  if (mpuInterrupt ) { // wait for MPU interrupt or extra packet(s) available
    GetDMP();
It seems when you copied the code you forgot to copy the function "getYawPitchRollInDeg".
pylon: It seems when you copied the code you forgot to copy the function "getYawPitchRollInDeg".
I did not, the code I have is exactly like that one.
In this case "that one" was not working too. It might help to get a link to "that one".
pylon:
In this case “that one” was not working too. It might help to get a link to “that one”.
Heres the code.
Sorry if I wasn´t specific.
MPU6050_Latest_code_Leonardo_int_pin_7.ino (7.88 KB)
That code has multiple problems. Did you write it or if not where did you get it from ?
That looks like the code that was offered to you in your other thread on this same subject https://forum.arduino.cc/index.php?topic=512118.msg3491423#msg3491423
If so then it really wasn’t very helpful because it doesn’t work. In fact it has obviously never been compiled or tested. In particular the error you’ve already noticed means exactly what it says…the code is trying to use a function that isn’t defined anywhere.
And of course it’s other characteristic is that there is absolutely nothing in there that has anything to do with driving any number of servos.
Steve
