I made a code to control a servo motor with Alexa. The Alexa part is ok. In fact it's all working fine but the servo motor is too fast.
This device is to control a ham radio memory knob. I can change the frequency of the radio with voice command and it's ok. But If the knob is at position (4) when I tell alexa to put it back to position (zero), the servo turn too fast and the rotary knob of the radio is skipping a frequency and the zero become position one. If I returne two position at the time, it's ok.
You can see my device if you follow the link below to my youtube.
[https://youtu.be/SxJI0r4N_qk?si=xGXmCZ6jdj0-3h0C]
You wont see the bug in the video because I'm returning to position Zero 2 positions at the time. The video is only to show you the device in action.
This is my code,
Is it possible to make the servo slower ?
* Download the libraries:
* Espalexa Library: https://github.com/Aircoookie/Espalexa
* AceButton Library: https://github.com/bxparks/AceButton
#include <WiFi.h>
#include <Espalexa.h>
Espalexa espalexa;
#include <ESP32Servo.h>
//OLED
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for SSD1306 display connected using I2C
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Servo myServo;
int inputAngle = 0;
#define wifiLed 14
boolean connectWifi();
// WiFi Credentials
const char* ssid = "MyRooterName";
const char* password = "The Password";
// device names will be recognize by Alexa
String Device_1_Name = "Repeater";
//callback functions
void Device_1(uint8_t setU1);
int u1Value;
boolean wifiConnected = false;
unsigned long previousMillis_1;
//***********************************SETUP BEGIN
void setup(){
myServo.attach(18);
//myServo.write(angle);
pinMode(wifiLed, OUTPUT);
//Make the LED flashing while waiting for the Radio to be ON
digitalWrite(wifiLed, LOW);
delay(200);
digitalWrite(wifiLed, HIGH);
delay(400);
delay(200);
delay(400);
delay(200);
delay(400);
// initialize the OLED object
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS))
{Serial.println(F("SSD1306 allocation failed"));
for (;;)
display.clearDisplay();
// Display Text
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(5, 0);
display.println("CrossBand");
display.setCursor(22, 20);
display.println("VE2IBN");
display.setCursor(5, 40);
display.println("version 9");
display.display();
delay(4000);
// Initialise wifi connection
wifiConnected = connectWifi();
if (wifiConnected){addDevices();}
else{Serial.println("Cannot connect to WiFi. So in Manual Mode");
delay(1000);}
}//***********************************SETUP END
//connect to wifi returns true if successful or false if not
boolean connectWifi(){
boolean state = true;
int i = 0;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connecting to WiFi");
//Wait for connection
Serial.print("Connecting...");
Serial.print(".");
if (i > 20) {
state = false; break;}
i++;}
Serial.println("");
if (state) {
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP());}
else {Serial.println("Connection failed.");}
return state;
void addDevices(){// Define your devices here for Alexa.
espalexa.addDevice(Device_1_Name, Device_1);
espalexa.begin();
void Device_1(uint8_t setU1){
if (setU1 > 0){u1Value = (map(setU1, 0, 254, 0, 100) -1);}
void servoControlStep(){
myServo.write(inputAngle);
if ((u1Value >=0) && (u1Value <=4)){inputAngle = 70;}
if ((u1Value >=6) && (u1Value <=14)){inputAngle = 60;}
if ((u1Value >=16) && (u1Value <=24)){inputAngle = 50;}
if ((u1Value >=26) && (u1Value <=34)){inputAngle = 40;}
if ((u1Value >=36) && (u1Value <=44)){inputAngle = 30;}
if ((u1Value >=46) && (u1Value <=54)){inputAngle = 20;}
if ((u1Value >=56) && (u1Value <=64)){inputAngle = 10;}
void timer_print(){//Serial print Data every 2 seconds
unsigned long currentMillis_1 = millis();
if (currentMillis_1 - previousMillis_1 >= 2000){
printData();
previousMillis_1 = currentMillis_1;
void printData(){//for debug
Serial.print("u1Value: ");Serial.println(u1Value);
Serial.print("inputAngle: ");Serial.println(inputAngle);
void OledPrint(){
if (u1Value == 0){display.setTextSize(2);display.setCursor(2, 45);display.print("Memory: 00");}
if (u1Value == 10){display.setTextSize(2);display.setCursor(2, 45);display.print("Memory: 10");}
if (u1Value == 20){display.setTextSize(2);display.setCursor(2, 45);display.print("Memory: 20");}
if (u1Value == 30){display.setTextSize(2);display.setCursor(2, 45);display.print("Memory: 30");}
if (u1Value == 40){display.setTextSize(2);display.setCursor(2, 45);display.print("Memory: 40");}
if (u1Value == 50){display.setTextSize(2);display.setCursor(2, 45);display.print("Memory: 50");}
void loop(){
servoControlStep();
timer_print();
OledPrint();
//**************************************Section for Wi-fi connect
if (WiFi.status() != WL_CONNECTED){digitalWrite(wifiLed, LOW);}
else{digitalWrite(wifiLed, HIGH);
if (wifiConnected){espalexa.loop();
delay(1);}
else {wifiConnected = connectWifi();
if(wifiConnected){addDevices();}
display.setTextSize(1);display.setCursor(35, 0);display.println("Connected");
display.setTextSize(1);display.setCursor(25, 20);display.println(WiFi.localIP());
display.display();
