Hi, i am new to arduino so please be understandable.
I am working on projeckt where i need to include servo motor or something similar, which
will be able to turn 30 times x 360 degree, but i need a constant feedback, in which position is the
motor. Should i use servo, stepper or some other motor? I need torque for example 20kg/cm
and speed is not important.
20kg/cm is not a torque value, its a linear mass density. 20kgf-cm (kilogram-force centimeter)
is a torque, and its 2Nm approx, which means you'll either need a large stepper (NEMA34
running at several amps), or a gear-motor with an encoder and a PID-loop to provide
servo-control (turn the motor into a servo-motor).
Note that hobby servos are not to be confused with a full-blown servo motor which has
controllable position with no limits on rotation - industrial servo-motors are very expensive,
but it is possible to roll you own given a motor, motor driver and an encoder and operating a
feedback loop in software.
You can add gearing to a stepper motor if a smaller stepper would be better, but without
knowing the power requirement there's no real way to judge what your application needs.
