Servo motor troubleshooting
Good day everyone,
I got a servo motor that i will use in my future project. I tried servo sweep example in arduino.
now after the necessary connections, i run the program. The result is not satisfying.
the servo motor turns a full rotation clockwise 5 times then it turns 1 (450degrees) counterclockwise.
The servo sweep program meant to make the servo to rotate 180degrees back and forth motion, similar to a car’s windshield wiper.
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
Connections:
servo motor has 3 wires, for power i connect it to 5v and ground pins of arduino board.
and the output wire to pin 9 of arduino board.
What might be the problem?
Should I power up the servo motor to a external power 6v?
Or worst, I got a defective servo motor.
Seems that what you have there isn’t a pure servo, but a continuous rotation servo. On one of those, the value you send isn’t degrees anymore, but a direction and speed. ~90 is stationary, values <90 are one direction and >90 the other. 0 and 180 are full speed.
Thanks for the reply, I’m just new to servo application. But to clarify about the servo i used here’s the link.
http://www.e-gizmo.com/PRODUCT/servo%20motors.pdf
In the link the blue servo is the one i used.
As far as I know that's a "normal" servo, not a "continuous" one, but maybe its been modified?
And as a matter of principle, you should use a separate power supply for a servo and not power it off the Arduino. Just make sure you tie all the grounds together.
Servo test code that might identify how your servo operates.
// zoomkat 12-25-13 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// Send an a to attach servo or d to detach servo
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include <Servo.h>
String readString; //String captured from serial port
int n; //value to write to servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7, 500, 2500);  //the pin for the servo control, and range if desired
  Serial.println("servo all-in-one test code 12-25-13"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
      // attach or detach servo if desired
    if (readString == "d") {
      myservo.detach(); //detach servo
      Serial.println("servo detached");
      goto bailout; //jump over writing to servo
    if (readString == "a") {
      myservo.attach(7); //reattach servo to pin 7
      Serial.println("servo attached");
      goto bailout;
    n = readString.toInt();  //convert readString into a number
    // auto select appropriate value
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
bailout: //reenter code loop
    Serial.print("Last servo command position: ");
    Serial.println(myservo.read());
    readString=""; //empty for next input
