Servo Motor Trying to Sweep but not Working
I am using the TowerPro SG-5010 servo motor and an Arduino Uno and using the example sweep sketch from the Arduino IDE Libraries for Servo Motors. It's connected to GND, pin 9, and 5V pins. I am also using a 9V battery as a power source. However, when it's not moving to the position in the code. It's trying to move, but it only makes ticking noises and doesn't actually move. I also swapped the motor for another of the same make and model and the same thing happened. However, when I swapped it out for a TowerPro MicroServo 9g SG90, it moved with no problems.
Any reason why this is happening, and how can I fix it to work with the TowerPro SG-5010?
Not enough power for the larger servo. The 5V pin can't supply very much. Try powering the servo separately from a battery 4 x AA cells, preferably NiMH rechargeables. Connect battery negative to servo - and Arduino ground and positive to servo +.
Steve
NEVER use the 5V pin to power motors or servos, despite the many bad tutorials that tell you to do so. You can damage the Arduino doing that.
Use a separate power supply and connect all the grounds. 4xAA batteries will usually work for 1-2 servos.
mayamac-seid:
if you are using high power servo motor then 5 volt is not enough power, use extra power for servos, servo do always creates ticking noise, do check any kind or shortage or signal missing problem.
Jack_Arsal:
The voltage required is not a matter of speculation, it's a matter of reading the data sheet. Many high end servos are indeed 5V.
You shouldn't bandy the word "power" about willy nilly on a forum like this: in physics power has a specific meaning, as the rate of doing work, and in electrical terms it's volts x current.
So yeah, you're probably right that OP needs extra power, but not from volts: it's the lack of current that's usually the issue.
The problem is indeed lack of power.
A properly designed voltage regulator shuts down if too much current is drawn, and the output voltage will drop, sometimes to zero.
