servo motor with arduino
am trying to power up 5 servos with arduino uno. would a 6v 2-3amp battery unit sufffice?
servos have no load current of .17amps and stall current of 1.1amps
(deleted)
bibliophile: am trying to power up 5 servos with arduino uno. would a 6v 2-3amp battery unit sufffice?
If you mean a 6V 2-3 Ah then probably. What type of battery is it?
If you mean the battery can only provide 2-3A then probably not.
Steve
I ended up getting Duracell power pack 6v 3.3amp
it works perfectly thanks for all ur help
You are still confusing current in amps with capacity in ampere-hours. A 3.3Ah battery holds a charge of 3.3 x 3600 coloumbs. Its max current discharge rate is a different matter.
